Parameter Is Incorrect External Hard Drive Fix Without Formatting, Is It Possible?
My external hard drive suddenly shows “The parameter is incorrect” when I try to open it in Windows. It has important files on it, so I’m trying to fix the external hard drive error without formatting or losing data. What safe steps should I try first?
Be a little cautious with this error. 'The parameter is incorrect' doesn’t always tell you what actually went wrong. It can show up after a bad disconnect, a power cut, a loose or failing USB cable, or file system damage. Windows may refuse to open the drive even though the data is still sitting there.
The main thing is: don’t write anything to that drive yet. Don’t format it, don’t copy new files to it, and don’t rush into CHKDSK if the files matter. CHKDSK can fix some file system problems, but on a damaged drive it can also change, move, or remove broken file system entries while trying to repair them.
Start with the simple stuff first:
  1. Swap the USB cable.
  2. Use a different USB port, ideally a rear port on a desktop.
  3. Try the drive on another computer.
  4. Check Disk Management and see if the drive shows up with the correct size.
If Disk Management still sees the drive, even if File Explorer says it’s inaccessible, recovery is often still possible.
For getting the files off, Disk Drill is a reasonable place to start. It’s useful in cases where Windows can detect the device but can’t read the file system properly.
The safer way to handle it is something like this:
  1. Install Disk Drill on your main system drive, not on the damaged external drive.
  2. Open it and see if the external drive appears in the list.
  3. If the drive is disconnecting, acting slow, or making odd sounds, create a Byte-to-byte Backup first. That gives you a full image of the drive so you can scan the copy instead of putting more stress on the original.
  4. Scan the image, or scan the drive directly if it seems stable.
  5. Run a Universal Scan so it can look for existing files, deleted files, and anything recoverable from the damaged file system.
  6. Use preview before recovering. If your photos, documents, or other important files preview normally, that’s a good sign.
  7. Save recovered files to another drive. Never recover them back onto the problem drive. The free Windows version allows up to 100 MB of recovery, which is enough to check whether the files are actually recoverable before paying for more.
After the important files are copied somewhere safe, then it makes sense to try repairing the drive.
If it’s still showing as NTFS, exFAT, or FAT32 and Windows assigns it a drive letter, you can run:
chkdsk X: /r
Replace X with the correct drive letter.
If CHKDSK says the drive is RAW, or it refuses to run, try TestDisk instead. It can often rebuild damaged partition information or recover lost partitions without formatting the drive.
If repair tools don’t get it working, a quick format is usually the next step, but only after the files are backed up. If the problem was only file system corruption, a new file system may clear the error. If the same issue comes back after formatting, I wouldn’t keep using that drive for anything important. At that point it starts looking like a hardware problem.
There’s also one odd Windows-related thing worth checking. If you’re seeing 'The parameter is incorrect' with other drives or in unrelated Windows tasks too, look at your regional settings. A wrong decimal separator has triggered this error for some people, though connection problems and file system damage are much more common.
If the drive vanishes from Disk Management, clicks, repeatedly spins up and down, or S.M.A.R.T. tools show a lot of pending or reallocated sectors, stop poking at it. That usually points to failing hardware, and keeping it powered on can make recovery harder. In that case, a professional recovery lab is the safer move.
Formatting is not the fix if the files matter. Try mounting the drive read-only from a Linux live USB first, because sometimes Windows throws “parameter is incorrect” while another OS can still copy the files off. If it mounts, copy everything to a separate drive before running any repair tool.
If Disk Management shows the external drive with the correct total capacity, then yes, recovery without formatting is possible. If it shows 0 bytes, “No Media,” or keeps disappearing, treat it more like hardware failure and stop trying software fixes.
The detail people often miss is whether they are scanning the drive letter or the actual physical disk. If Windows says the parameter is incorrect, the drive letter may be useless because Windows can’t read the file system properly. In recovery software, pick the whole external disk device if it appears, not just “E:” or “F:”. That gives the tool a better chance of finding the old partition and files. Same idea with Disk Drill, TestDisk, R-Studio, DMDE, etc. Install the tool somewhere else and recover to somewhere else.
I’d push CHKDSK to the “after recovery” stage, not the first stage. It may make the drive open again, but it can also make a messy file system even messier from a recovery point of view. Formatting is the last step only after your files are copied off. A format might make the drive usable again, but it is not a data-preserving fix for this error.
Don’t click “Initialize,” “Convert,” or “Format” in Disk Management just because Windows offers it. If the drive shows the right size, clone or recover from it first, then mess with repairs later, because those prompts are for making Windows happy, not for protecting your files.
