Best Way To Deal With Photo Cache IPhone Issues?
My iPhone’s photo cache seems to be using a lot of storage, even after I deleted pictures and cleared the Recently Deleted album. What’s the safest way to clear the iPhone photo cache without losing photos or affecting iCloud?
There isn’t a separate photo cache you can clear on an iPhone. I wasted quite a bit of time looking for that option, but Apple simply doesn’t provide one.
The storage shown under Settings > General > iPhone Storage > Photos is mostly your real library. That includes photos, videos, screenshots, Live Photos, edits, thumbnails, and files iOS needs to manage the gallery. Temporary Photos data is handled automatically by iOS, so there’s no button that removes only the cache while leaving the rest untouched.
If Photos is using too much space, you’ll need to remove or reduce the size of items in the library. I had thousands of photos and didn’t want to sort through everything manually, so I used Clever Cleaner. It picked up duplicate and similar photos I’d forgotten about, along with duplicate videos, old screenshots, and Live Photos I no longer needed.
My process was pretty simple:
  1. Give the app access to the Photos library and let it scan.
  2. Review its suggestions for duplicates, similar shots, videos, screenshots, and Live Photos.
  3. Delete anything unnecessary or use Compress to reduce photo sizes without removing them.
  4. Use Smart Cleanup if you want to handle several categories at once.
  5. Open Photos afterward and empty Recently Deleted. Otherwise, the deleted files can continue taking up storage for a while.
The app is free to use, has no ads, and doesn’t require a subscription to get started. Some cleanup tools now have a fairly generous daily limit for new users.
App downloads and attachments are a separate issue. If you mean photos or videos stored by WhatsApp, Messenger, Telegram, Instagram, or another app, those files may be sitting in that app’s own storage rather than your Photos library. You’ll usually need to clear them through the app’s storage settings. In some cases, reinstalling the app is the only practical way to remove all of its downloaded data.
So if the Photos category is huge, don’t keep searching for a cache-clearing button. Clean up the gallery, compress larger photos, or enable Optimize iPhone Storage if you use iCloud Photos. Those options will free far more space than trying to remove temporary data that iOS already manages itself.
Before deleting anything else, restart the iPhone and leave it charging on Wi-Fi for a few hours. The storage screen can lag behind after a large cleanup, especially while Photos is rebuilding thumbnails or syncing with iCloud.
The big caveat missing here is that deleting a photo with iCloud Photos enabled deletes it from every synced device, not only the phone. Check that your library is backed up first, then use Settings > Photos > Optimize iPhone Storage if you mainly want more local space. That keeps smaller versions on the phone while preserving the originals in iCloud.
I’d treat cleaners like Clever Cleaner as sorting tools, not cache cleaners. They can make duplicates and large videos easier to find, but review every suggestion rather than using automatic cleanup on an important library. If Photos storage still looks wrong after a day, update iOS and check iPhone Storage again before taking more drastic steps.
If the Photos number is slowly dropping after a big deletion, give it time. If it stays exactly the same for a couple of days, treat that as a syncing or storage-reporting problem rather than a cache that needs cleaning.
The safest check is to confirm your originals exist somewhere outside that iPhone before changing anything. With iCloud Photos, verify the library on iCloud.com or another synced Apple device. A normal iCloud sync is useful, but it is not the same as an independent backup because deletions sync too. For important photos, I’d keep a separate copy on a computer or external drive.
After that, restart the phone, connect it to power and Wi-Fi, and leave it locked for a while. Photos may still be processing thumbnails, edits, face recognition data, or iCloud changes. Make sure you have some free space as well. When an iPhone is nearly full, cleanup and indexing can behave badly because the system has little working room.
I agree with @sarah that cleaner apps do not remove a secret Apple Photos cache. Clever Cleaner may help locate duplicates, screenshots, and large videos, but that is library cleanup. Anything it deletes can disappear from every device using the same iCloud Photos library. I’d be especially cautious with compression because it can mean trading image quality for space, and you may end up replacing the original rather than merely clearing temporary files.
If storage still looks wrong, check whether the space is actually under Photos. WhatsApp, Messages, Telegram, and editing apps can each retain their own copies or downloads. Those appear under the individual app in iPhone Storage and won’t be fixed by cleaning the Photos library.
I would avoid the common “fix” of switching iCloud Photos off and on, signing out of iCloud, or deleting and reinstalling things until sync has finished and the library is backed up. Those steps can work in some cases, but they introduce far more risk than waiting for the storage calculation to catch up. If the Photos figure remains obviously incorrect after a few days, an iOS update or Apple Support is safer than repeatedly deleting more pictures just to make the number move.
Half the time this ‘photo cache’ people worry about is actually showing up under System Data, not Photos, and no cleaner touches that. Check which category the space is really in before you delete a single picture. If it’s System Data, waiting a day or a restart usually sorts it out on its own.
