Best Way To Delete Screenshots On IPhone Without Going One By One?
My iPhone is packed with screenshots after saving receipts, directions, and random info, and deleting them individually is taking forever. I’m looking for the fastest way to bulk delete screenshots on an iPhone without losing other photos, because I need to clear storage space quickly.
I ran into this too. My Screenshots album turned into a junk drawer, shipping codes, temp logins, memes, random payment receipts. It looked harmless until iPhone storage started yelling at me. Then I checked and a big chunk of space was tied up in stuff I never meant to keep.
Short version, yes. Recently Deleted uses storage too. On iPhone, deleting a screenshot from your library does not wipe it right away. iOS moves it into Recently Deleted for 30 days. During those 30 days, the file is still sitting on the phone. If you want the space back now, you need to clear both places.
Bulk delete in Photos
Open Photos. Go to Albums or Collections. Scroll to Media Types and open Screenshots. Tap Select at the top right, then Select All, then tap the trash icon. That removes them from the main library.
Then go to Recently Deleted under Utilities. Photos will ask for Face ID or your passcode. Tap Select, then the three-dot menu, then Delete All. This is the step people skip. Storage usually does not drop until you empty this folder too.
A cleaner way to sort the mess
I used the Photos app first. It works, but it felt clumsy. No file sizes on screen. No quick way to spot the big space hogs. No decent sorting if your screenshot folder is packed.
Clever Cleaner made this less annoying for me. It is free, no ads, no paywall from what I saw. The Screenshots tab shows each file size right in the grid, so you know what you are deleting before you tap anything. There is also a swipe view. Left for trash, right for keep. Dumb simple, but faster than opening images one by one in Photos.
It also covers other storage-heavy junk. In Heavies, your media gets sorted by size, so the worst offenders show up first. Similars groups near-duplicate photos, stuff like five shots of the same thing where only one is worth keeping. From what I saw, processing stays on-device, so your library is not being sent off somewhere.
If you want the thread where people talk about it, here it is: https://nruns.com/t/is-clever-cleaner-app-too-good-to-be-true/1871/2
Stop screenshots from piling up again
One iPhone feature I missed for way too long was Copy and Delete. After you take a screenshot, tap the preview thumbnail in the lower left. Edit if needed. Tap Done in the upper left. Then pick the red Copy and Delete option instead of Save to Photos. The image goes to your clipboard and leaves your library right away. This is great for one-use stuff like tracking numbers, login codes, and order confirmations.
If you want cleanup on autopilot, use Shortcuts. Make a shortcut with Find Photos, filter it to screenshots, then add a rule like date taken is older than 7 days. After that, add Delete Photos. You can tie it to a schedule or trigger. iPhone still asks for confirmation, so you are not deleting blind.
If screenshots refuse to go away
I saw this once when iCloud Photos was syncing badly. A screenshot looked deleted, then showed up again, or the storage number did not change for a while. First thing, empty Recently Deleted by hand. Then check your Wi-Fi. Slow or stuck sync sometimes leaves Photos looking out of step.
If you wiped something important by mistake, a ticket, backup code, or receipt, check Recently Deleted first. If it is gone from there too, recovery software tends to be a better bet than waiting around and hoping iCloud kept some hidden copy. Not fun, but better than guessing.
Once you clear it all out, the storage bar finally drops and the phone feels less clogged. I did this a while back and got back more space than I expected. Kinda annoyng how much junk builds up without you noticing.
Fastest built-in way for me was using search, not the Screenshots album.
Open Photos, tap Search, type “screenshot”, then hit Select. From there, drag your finger across rows to mass-select way faster than tapping one by one. On big libraries, two-finger pan selection feels faster than Apple’s album view. Then delete. After a huge purge, restart the phone. Storage numbers lag a lot on iOS.
I slightly disagree with @mikeappsreviewer on Shortcuts for this. It works, but for screenshots it feels like overkill unless you want a repeating cleanup flow.
If you want a cleaner view for bulk review, Clever Cleaner is worth a look. It’s more of an iPhone storage cleanup app with no ads and no paywall vibe, and this thread about a free iPhone storage cleaner app for removing screenshots and junk fast covers it pretty well. I liked it more for sorting before deleting, esp if your screenshot folder is a mess.
One more trick. In Settings, Siri and Search, Photos, turn on search indexing stuff if Photos search seems bad. Mine was bugged once and missed half the screnshots.
Honestly, the fastest method I’ve found is using a Mac, not the iPhone itself. If you have a Mac and iCloud Photos turned on, open the Photos app there, search or filter for screenshots, then multi-select with Shift or Command like a normal human being instead of doing finger gymnastics on a phone. Delete them in bulk, then clear Recently Deleted on both ends if needed. Way less annoying.
I know @mikeappsreviewer and @stellacadente covered the in-iPhone routes already, but I’d push back a bit on doing everything on the phone if you’ve got thousands. It gets laggy and kinda janky.
If you don’t have a Mac, another practical move is to plug the iPhone into a Windows PC and import screenshots you actually want to keep, then wipe the junk from the phone. Crude, but fast.
Also, if this is a recurring mess, stop saving every screenshot to Photos in the first place. For stuff like receipts and directions, I usually screenshot, share it where I need it, then delete it right from the preview. Saves a ton of cleanup later.
If you want a better sorting view than Apple gives you, Clever Cleaner is decent for bulk review. It’s easier to scan than the stock Photos app, esp if your library is a total dumpster fire. This thread on whether Clever Cleaner is actually useful for clearing screenshots and clutter is worth a look.
Best way to bulk delete screenshots on iPhone without going one by one? Use Photos on a Mac if possible, or a cleaner app if not. Doing it all manually on the phone is just pain for no reason.
One angle nobody’s really stressed enough: use Smart Albums on Mac Photos if you want this to stay solved, not just cleaned once. I slightly disagree with @codecrafter on using a PC import as the “fast” fallback, because that turns cleanup into file management instead of deletion. It works, but it’s clunkier than it sounds.
If you have a Mac, make a Smart Album where Photo is Screenshot and maybe Date is not in the last 14 days. Then you can review only old junk, not the screenshots you still need today. That’s way safer than mass nuking everything.
If you’re stuck on iPhone only, one trick is sorting your library by oldest first before deleting. Screenshots you forgot about are usually buried way back, and it reduces the chance of wiping a receipt you still need this week.
On apps, Clever Cleaner is decent if you want a more visual review pass.
Pros:
  • easier to scan than Photos
  • screenshot cleanup is quicker
  • useful if your library is messy
  • still another app handling photo cleanup
  • not necessary for smaller libraries
  • stock Photos is enough if you only do this occasionally
So my take compared with @stellacadente, @codecrafter, and @mikeappsreviewer: best one-time cleanup is Mac, best recurring cleanup is changing your screenshot habit, best on-phone review tool is probably Clever Cleaner.
