Can someone explain the difference between OneDrive and SharePoint?
I’m confused about when I should be using OneDrive vs SharePoint for storing and sharing work files in Microsoft 365. I’ve been saving documents in OneDrive, but my team keeps creating SharePoint sites and I’m not sure which is best for personal files, team collaboration, or long-term document storage. Can someone break down the key differences, best practices, and real-world examples so I don’t misplace important files or set permissions wrong?
I feel like Microsoft could save everyone a lot of confusion if they just said this upfront:
  • OneDrive = your personal work drive
  • SharePoint = your team’s shared drive
That’s basically how I explain it to new people at work. Your OneDrive is like your personal desk drawer. SharePoint is the shared filing cabinet for your department.
What makes it confusing is they’re both part of Microsoft 365 and technically OneDrive even runs on SharePoint in the background. So people see similar interfaces and assume they’re the same thing. They’re not. One is about you, the other is about the group.
What OneDrive is good for
I use OneDrive mostly for my own working files. Draft documents, notes, stuff I’m not ready to share yet, random exports, that kind of thing.
It’s good for:
– Files you work on across multiple devices
– Sharing something quickly with one or two people
– Offline work that syncs later
– Just having your stuff follow you between machines
It’s pretty low effort. Log in, save files, done. No real structure needed unless you want it.
What OneDrive isn’t great at
Where it starts getting messy is when people try to turn it into a team file server.
I’ve seen people share like 15 folders with different combinations of people and then nobody remembers who has access to what. Permissions turn into a guessing game pretty fast.
Also there’s no real “team space” feeling. It’s still just your personal folders with sharing added on top.
And yeah… the sync client is usually fine but I’ve definitely seen it act weird on older laptops and a couple Macs in our office. Nothing catastrophic, just the usual “why hasn’t this synced yet” moments.
What SharePoint is good for
SharePoint makes more sense when you think of it as the place where team files are supposed to live.
We use it for:
– Department document libraries
– Project spaces
– Internal pages and resources
– Version history when multiple people edit stuff
Also something a lot of people don’t realize: every Teams channel stores its files in SharePoint. So if you use Teams, you’re already using SharePoint whether you know it or not.
Where it helps is structure. Whole teams can access the same library, permissions can be set at different levels, and files don’t “belong” to one person who might leave the company.
What SharePoint isn’t great at
I won’t lie, the learning curve is real.
If someone just wants to find one file, SharePoint can feel like wandering around a mini company website. Lots of sites, subsites, libraries… it can get confusing fast if nobody organizes it properly.
Also if IT doesn’t keep an eye on it, sites multiply like rabbits. I’ve seen companies with five different SharePoint sites for basically the same team because nobody cleaned things up.
Search is better than it used to be but I still sometimes search the exact file name and somehow it doesn’t show up until I manually browse to it.
And for personal files it’s just overkill. Nobody needs a whole SharePoint site for their own notes.
What real users tend to say
From what I see at work and in forums:
Most individual contributors like OneDrive because it’s simple and feels like a normal folder.
Team leads and project managers usually start liking SharePoint once they understand how it keeps team files organized and not tied to one person.
And the most common mistake I see: people storing team documents in their OneDrive, sharing links, then months later nobody can find anything because it’s sitting in someone’s personal storage. Happens all the time if nobody explains the difference early.
The actual differences, side by side
If I had to explain it simply:
OneDrive is for files that start with you and maybe get shared later. SharePoint is for files that start with the team from day one.
OneDrive permissions usually happen when you manually share something. SharePoint permissions are usually set at the team or site level first.
If a project grows beyond just you and a couple people, that’s usually when it belongs in SharePoint instead of OneDrive.
Using both at the same time – and where CloudMounter helps
In reality most of us end up using both. I keep my personal working stuff in OneDrive and anything team related goes into SharePoint.
What gets annoying is constantly jumping between them. Browser tabs, Teams, OneDrive folders, SharePoint sites… it adds up.
I started using CloudMounter mostly because I got tired of all the switching. It lets me mount OneDrive and SharePoint like regular drives on my computer, so they just show up in Finder (or File Explorer on Windows). I can open and move files between them like normal folders instead of digging through web pages.
The best part is that it doesn’t force a sync of everything to your hard drive, so you can browse a 1 TB OneDrive account without actually using 1 TB of your own disk space. It’s especially helpful if you’re managing a server alongside your cloud accounts, as it handles both in the same window.
Short version for how to think about it:
• OneDrive = “mine, for now”
• SharePoint = “ours, long term”
I agree with most of what @mikeappsreviewer said, but I think the “OneDrive is personal, SharePoint is team” rule is a bit too simple on its own. Your real decision should be based on ownership, lifespan, and risk.
Use OneDrive when:
• You are drafting, experimenting, or taking personal notes.
• You are not sure the work will even survive the week.
• You only share with one or two people and it is OK if the link dies someday.
• The file is tied to you as a person, like performance notes, your own task lists, learning docs.
Typical OneDrive examples:
• First draft of a proposal before your manager even knows it exists.
• Raw meeting notes that you clean up later.
• Quick exports from tools you will throw away after copying the data.
Where I slightly disagree with the “start with OneDrive” advice:
If you start something you already know will become a team asset, do not park it in OneDrive first.
Example: a new budget tracker the whole team will use next quarter. Put it in the right SharePoint library from day one, even if you are the only editor this week. That avoids link churn and file moves later.
Use SharePoint when:
• The team, department, or project owns the result.
• Someone needs to find it six months from now without pinging you.
• It ties to a process, policy, client, or product.
• You expect staff turnover during its lifetime.
Typical SharePoint examples:
• Project folders, client deliverables, SOWs, design docs.
• Official templates for reports, decks, budgets.
• Department policies, onboarding docs, runbooks.
Practical rules you can follow tomorrow:
  1. If a file is referenced in a recurring meeting, put it in SharePoint.
  2. If it is “source of truth” for numbers, put it in SharePoint.
  3. If your manager would panic if you left and took it with you, put it in SharePoint.
  4. If you only need it this week and nobody else cares, keep it in OneDrive.
How to move from your current “everything in OneDrive” setup:
Step 1: Create a simple structure in SharePoint
Ask whoever owns your team site to set up 3 to 6 top folders or libraries like:
• 01 Projects
• 02 Clients
• 03 Team Docs
• 04 Templates
Step 2: Move, do not copy
From your OneDrive, move files into SharePoint so there is only one “real” version.
Use Explorer/Finder with Sync, or a tool like CloudMounter if you want both OneDrive and SharePoint mounted as drives without syncing all content to your disk.
CloudMounter matters here because:
• You can see OneDrive and multiple SharePoint libraries side by side in your file manager.
• You drag from “your” drive to the team library without worrying about disk space.
• It keeps things simple for you if you hate jumping between browser tabs and Teams.
Step 3: Change your habits going forward
• New team docs: create in the right SharePoint library from the start.
• Personal prep work: OneDrive, then “Save As” into SharePoint once it is team ready.
• Stop sending attachments. Share the SharePoint link to the file that lives in the team space.
Quick decision checklist:
Ask yourself before saving:
• Who owns this in 6 months, me or the team?
– You: OneDrive
– Team: SharePoint
• Will this be mentioned in a process, SOP, or official doc?
– Yes: SharePoint
• If IT disabled my account tomorrow, should this survive without effort?
– Yes: SharePoint
If you follow that for a month, your OneDrive becomes your working desk and SharePoint becomes your file room. And your “where did that file go” problems drop fast.
Think of it this way:
  • OneDrive = “my stuff, tied to my account”
  • SharePoint = “our stuff, tied to a team / site”
I like @mikeappsreviewer’s “mine vs ours” and @cazadordeestrellas’s “ownership / lifespan / risk” angle, but I’d tweak it a bit:
If a file will be:
  • Used in recurring meetings
  • Referenced in a process, SOP, or by future teammates
  • Needed even if you quit or get hit by a bus
…it belongs in SharePoint from day 1, even if you’re the only person touching it today. Parking those in OneDrive “just for now” is how you end up with broken links and “who has the real version?” drama.
Where I don’t fully agree with others:
You don’t have to “start everything in OneDrive.” For planned deliverables (project docs, client stuff, budget trackers), I create them directly in the proper SharePoint library. One less move, one less chance to lose context.
Concrete rule of thumb:
  • Brain dump, scratchpad, personal notes, drafts that might die tomorrow → OneDrive
  • Anything that represents a project, client, policy, template, or shared tracker → SharePoint
On the practical side, juggling both in a browser is annoying. If you’re on desktop, a tool like CloudMounter is actually worth it: you can mount both OneDrive and your SharePoint libraries as drives in Finder / Explorer, then just drag files between “me” and “team” spaces without syncing everything locally or hunting URLs. That part saves a ton of time once your org has a forest of sites.
If you apply just this filter before saving:
“Who should own this in 6–12 months, me or the team?”
you’ll usually pick the right place and avoid the “where did my file go” mess.
