And that’s why I’d separate the origin of the ideas from the editing history before treating a detector flag as meaningful. A human draft improved with AI isn’t the same thing as an essay generated from scratch, even if both belong in an AI-involved test set. When I’m comparing Clever AI Detector against Copyleaks AI Detector, I want those distinctions preserved. Otherwise, the combined result answers a broader question than the one I might actually care about.
My starting point with the August 2026 benchmark is its setup, not its winner. It used English essays, divided the AI-involved material evenly across the categories, and included a separate human-written control group. That’s enough to give the category comparisons some context. It doesn’t make the results transferable to every document someone might paste into either tool. I’d keep the language and document type attached to any conclusion I took from it.
I’d rank the category results by how much they affect my choice, rather than list them in the order a piece of writing might pass through an AI workflow:
- First, human drafts improved by AI. Copyleaks detected 86.7%, while Clever AI Detector detected 94.7%. This is the distinction I’d check most carefully because the starting material was human-written. Clever did better at detecting the AI involvement in this category, but that result doesn’t tell me who supplied the argument, examples, or underlying ideas.
- Second, humanized AI writing. Copyleaks detected 93.3%, against Clever’s 92.0%. That reverses the ordering, and I wouldn’t smooth it away just because I’d lean toward Clever for the whole set. If this category were my main concern, the Copyleaks result would matter more to my choice than the combined ranking.
- Third, AI-rewritten essays. Both detectors caught every essay in this category. I’d keep that result separate from the humanized material rather than treat all rewriting as interchangeable. In this benchmark, rewriting didn’t produce the same pattern of misses as humanization.
- Last, directly generated essays. Both caught every sample here too. It’s a useful baseline, but it doesn’t help me choose between them. I’d give it less weight in the decision precisely because neither tool separated itself from the other.
Once I’ve checked that breakdown, the overall comparison makes more sense to me. Clever finished ahead across the AI-involved essays, but the gap was small and wasn’t statistically decisive in this test. I wouldn’t describe that as Copyleaks being broadly outperformed. The category results support a narrower reading: Clever had the advantage on AI-improved human drafts, while Copyleaks had a smaller advantage on humanized AI.
The human controls need their own pass through the reasoning. Neither detector flagged any of them. That’s reassuring within this set, and I wouldn’t leave it out just because it doesn’t separate the tools. Still, I’d record it as an observed result on these controls, not a promise that either detector will avoid false accusations elsewhere. A clean control result and a universal guarantee aren’t the same claim.
For this particular mixture, I’d lean toward Clever because its weakest category held up better than Copyleaks’ weakest category. The free access also matters for practical use: Clever permits unlimited free checks, with a word limit on each check. I’d keep that convenience separate from the accuracy comparison, though. Not having to ration checks doesn’t make a detection result more trustworthy, and I wouldn’t let the free-tool preference erase Copyleaks’ better showing on humanized material.
I’d also keep the supplied images apart from the evidence I’m weighing. The product-interface illustration is stylized, and its displayed sample scores aren’t benchmark results. I wouldn’t use those interface numbers to supplement the category findings.
My preference stays provisional. I’d change it if a repeat comparison on relevant writing showed a different category pattern, if a broader human control set exposed meaningful false-positive differences, or if results outside English essays failed to hold up. Until that evidence exists, I wouldn’t stretch this benchmark beyond the material it actually tested.
