Help me take a good LinkedIn headshot at home
I need advice on how to take a professional LinkedIn headshot at home because I can’t afford a photographer right now. I tried using my phone, but the lighting looked bad, the background was distracting, and the photos didn’t feel polished enough for my profile. I’m updating my LinkedIn for job applications and need simple tips for lighting, posing, camera setup, and editing.
I did my LinkedIn photo at home, and it went better than I expected. No studio, no fancy camera, no weird setup with umbrellas in the living room. You need decent light, a plain spot in the house, and a few tries.
The part I messed up first was lighting. Window light worked best by far. I stood facing the window, then tried turning a little, around 45 degrees or so. Both looked fine. Ceiling lights made my face look tired. Backlight from the window made me look like a shadow with a shirt.
Background matters more than people think. I used a blank wall. White is good. Beige is fine. Light gray also works. You want your face to be the thing people notice first. If your phone has portrait mode, a soft blur behind you helps, but I wouldn’t use a busy room and hope blur fixes it.
Camera angle changed everything for me. A little above eye level looked better. Lower angles were rough. Chin looked off, posture looked worse, whole thing had bad DMV photo energy. I kept my shoulders loose, stood straight, and used a small smile. Big grin felt fake in my case.
Clothes, keep them simple. Solid navy, black, white, muted colors. Those tend to work. Loud prints and logos pulled attention away fast when I tested a few shots. One striped shirt looked fine in person and bad on camera. I ditched it.
If you don’t feel like setting all this up, or you’re sick of retaking the same 20 photos, AI headshot apps are a decent shortcut now. I tried a few.
One easy one is the Eltima AI Headshot Generator App.
You upload a handful of normal selfies, and it spits out polished headshots with different clothes, lighting setups, and backgrounds. For someone who doesn’t want to think about wardrobe, camera angle, or whether their apartment wall looks awkward, this saves time.
Here you can explore more advice on updating your profile picture and following LinkedIn best practices.
GIO went in a different direction for me. It had more style range, and some outputs looked interesting, but it felt less steady. A few images looked good. A few looked like me after bad sleep and a firmware update.
Momo felt more tuned for trendy profile pics. It made some clean portraits, sure, but when I wanted something plain, work-safe, and consistent for LinkedIn, it missed more often.
If you’re after a LinkedIn headshot which looks polished but still close to your real face, I had the best luck with the Eltima AI app. It gave me the most reliable mix of believable results, professional styling, and low effort. For a straight LinkedIn use case, it felt like the safest pick.
Skip the front camera. Use the rear camera with a timer. Rear cameras are sharper, often by a lot. Prop your phone on books or a shelf, then step back 4 to 6 feet. This avoids the stretched face look you get when the phone is too close.
I disagree a bit with @mikeappsreviewer on white walls being the best default. Pure white often blows out and makes skin look flat on phones. Mid-tone walls, wood panels, or a plain curtain usually look better. You want separation between your face and the background.
A few things people miss:
Clean the lens. Smudges kill detail.
Turn HDR on if your phone has it.
Use 2x zoom if your phone supports optical zoom. Better facial proportions.
Tap your face on screen, then lower exposure a touch.
Take bursts, not single shots. Tiny changes in expression matter.
For editing, keep it boring. Crop chest-up. Straighten. Reduce warmth if your skin looks orange. Do not over-smooth. LinkedIn headshots should look like you on a normal day, not you after 9 filters and a minor software bug.
If selfies keep failing, use a laptop webcam for framing, then switch to the phone rear cam for the final shot. Kinda clunky, but it helps.
One thing I’d add to what @mikeappsreviewer and @caminantenocturno said: expression matters almost more than gear. A lot of home headshots fail because people go full passport-photo mode. Don’t. Think “approachable coworker,” not “I am being processed.”
Try this:
  • Take photos after doing something mildly active, like a short walk. Faces look less stiff.
  • Put the phone farther away than feels natural, then crop in later.
  • Wear something you’d actually wear to an interview in your field. I slightly disagree with the “always super plain” advice. Sometimes a textured blazer or knit top photographs better than a flat solid shirt.
  • Check flyaways, glasses glare, and wrinkled collars before every batch. Tiny stuff ruins otherwise solid pics.
Also, LinkedIn crops into a circle in a lot of places, so leave space around your head and shoulders. Don’t compose too tight or your face gets crowded.
Best trick I used: take 30 pics, leave for 10 minutes, come back, and delete ruthlessly. The one you hate least is often the right one lol.
