How do I connect my Brother printer to WiFi?
I’m having trouble setting up my Brother printer to connect to WiFi. I’ve followed the manual, but I keep running into issues and can’t seem to get it connected. Can anyone guide me through the steps or provide some tips to resolve this?
Alright, so connecting a Brother printer to WiFi should be easy, but because the printer gods like to torture us, it’s usually not. Here’s a step-by-step, assuming you didn’t already chuck it out the window:
  1. Preparation stage: Make sure your printer’s on, connected to power (duh), and located close to your WiFi router, cuz apparently these things can’t handle distance.
  2. Find the WiFi button thingy: Press the “Menu” button on the printer. Navigate through the settings using the up/down arrows (prepare to feel like you’re defusing a bomb) and look for Network settings or WLAN setup.
  3. Wizard Magic: Select ‘WLAN Setup Wizard.’ This sounds all mystical, but really, it’s just the annoying step where you’ll select your network from a list of possibilities.
  4. Enter Password: Here comes the fun part—typing in your WiFi password on a tiny screen with arrow buttons. Enjoy.
  5. Pray: If you’re lucky, the printer should connect. If it fails for no obvious reason, restart the printer, router, and maybe your faith in technology.
  6. Driver Drama: If it still isn’t working, check that your computer has the printer driver installed. If not, go to Brother’s website and download the driver for your specific printer model (yes, you might need to Google it).
  7. Test Print: Print something out. If your printer spits out a page, celebrate. If not, well…there’s always tech support or the comforting idea of going paperless forever.
Did wireless printing really revolutionize anything, or just up our collective blood pressure?
If you’re still battling the WiFi beast on your Brother printer, let’s consider a slightly different approach. While @waldgeist has outlined a solid process, sometimes it’s not the wizard or the driver, but the network itself causing chaos. WiFi printers can be oddly particular about network configurations. Here’s what might be tripping you up and how to untangle it:
  1. Check the Band: Some Brother printers only work on a 2.4 GHz network, and if your router is broadcasting on 5 GHz or operating on ‘combined’ mode, the printer might get confused. Split your network into separate SSIDs (if your router supports it) and make sure you’re connecting to the 2.4 GHz.
  2. Static IP Hack: Dynamic IP assigning can sometimes mess with your printer’s connection after setup. Log into your router settings and assign a static IP to your printer’s MAC address. It’s a bit techy, but it can prevent headaches later.
  3. WPS Button Shortcut: Not every Brother printer supports WPS, but if yours does, this can save you the endless loop of typing passwords. Press the WPS button on your router, then use the WPS option in the printer’s WLAN settings. They should sync up like magic (key word being should).
  4. Firewall Shenanigans: If your computer isn’t seeing the printer even after ‘successful’ WiFi setup, a firewall on your PC or router may be blocking communication. Temporarily disable it to test if that’s causing the problem, then whitelist the printer.
  5. Firmware Check: Outdated printer firmware can cause disconnects or outright rejection of your network. Go to Brother’s site and update it manually via USB if the WiFi isn’t cooperating.
  6. WiFi Range: You mentioned following the manual, so this might be redundant, but distance and interference (walls, devices, alien signals—whatever) are legit obstacles. Move the printer closer to the router during setup and see if it grabs the signal.
If none of this works, honestly, maybe it’s time to ask if a USB cable really is the enemy here. Sometimes a ‘good old-fashioned wired connection’ works better than fighting with these temperamental wireless setups. Wireless printing sounds modern, but let’s be real—it’s the tech world’s middle finger disguised as progress.
