How Do I Speed Up An Old IPad That Lags On Everything?
My old iPad has gotten painfully slow and now it lags when I open apps, browse the web, or even type. I’ve already tried restarting it and clearing some storage, but it still feels almost unusable. I need help figuring out how to make this old iPad faster or what settings to change before I give up on it.
Been there. My 6th gen iPad got so slow I started avoiding it. Safari took forever. YouTube would open like it was thinking about its life choices. I almost replaced it, then I spent a bit of time cleaning things up first, and the difference was bigger than I expected.
If the slowdown started right after an iPadOS update, I’d wait a little before doing anything drastic. After an update, the iPad spends hours doing background work, photo indexing, file cleanup, all of it. Mine got warm and felt sluggish for most of a day once. I left it alone, then did a full shutdown and turned it back on. Not sleep mode. Full power off, then boot again. It helped more than I thought it would.
Storage is the first thing I’d check. Old iPads hate running near full. Apple says 1GB free is enough, but on my device, things got ugly way before that. I try to leave around 10 to 15 percent of the storage empty. Once the space gets tight, app launches drag, switching between apps gets messy, and the whole system feels cramped.
I used to delete stuff by hand. Photos, videos, old apps, screenshots from 2021 for no reason. Total time sink. What worked better for me was using a cleanup app, mostly so I could see the biggest junk fast. The one I stuck with was Clever Cleaner. I found it after trying a few bad ones, and this one didn’t hit me with ads or a paywall every two taps.
What sold me was how it grouped things in a way I could act on fast. The Heavies section showed the giant files first, which made it easy to spot old 4K clips eating several gigabytes. The Similars section caught duplicate-looking photos, blurry shots, and bursts I forgot existed. It even broke out screenshots with file sizes, which was weirdly useful. I cleared around 5GB on mine, and the lag dropped off enough for me to notice right away. One thing I liked, and yeah I checked, was that it handled the scan on-device, so my photo library wasn’t getting pushed to some random server.
There are a couple settings changes I’d do too. In Accessibility, turn on Reduce Motion. The iPad stops doing those long zoom animations and uses simpler transitions. The chip isn’t faster, but the device feels less sluggish because you aren’t sitting through extra animation time. Then go to Display & Text Size and turn on Reduce Transparency. Older hardware seems to benefit a lot from cutting the blur effects.
Background App Refresh is another one. I turn it off fully on older iPads. Go to Settings > General > Background App Refresh. A bunch of apps keep checking in online when you aren’t even using them, and on weaker hardware, that adds up. I saw better battery life too, which was a nice side effect.
If the iPad feels slow only when loading pages or streaming, I’d check Wi-Fi before blaming the tablet. I spent a while tweaking settings once, then realized the issue was my 2.4GHz network being crowded. Switching to 5GHz fixed a lot of the delay. And if Safari is the main problem, clearing its stored data helps. Go to Settings > Safari > Clear History and Website Data. Annoying part is you’ll get signed out of sites, so heads up there.
On whether it’s time to replace it, my rule is pretty simple. If the iPad no longer gets the current iPadOS, I’d start looking at a refurbished newer one. If it still gets updates, I’d try cleanup and settings changes first. A lot of the time the tablet isn’t dead, it’s clogged up. Mine felt half broken. It wasn’t. It was full, noisy in the background, and dragging around effects it didn’t need. Small fixes got it back to usable, maybe more than usable tbh.
If it lags on typing too, I’d look at system load, not only storage. @mikeappsreviewer covered cleanup stuff well, but I don’t fully agree with turning off every background feature first. Sometimes the bigger win is finding one bad app or a worn battery.
Try this in order.
  1. Check battery health, if your model shows it. Old batteries cause throttling. If battery service is flagged, performance drops hard.
  2. Remove apps with bad reputations for memory use. Social apps, video editors, big games. Offload them, then test for a day.
  3. Disable Siri Suggestions in Search and widgets you never use. Those keep indexing data.
  4. Turn off Keyboard Dictation and predictive text for a test. If typing is laggy, keyboard services are often part of it.
  5. Reset all settings. Not erase. Settings > General > Transfer or Reset > Reset > Reset All Settings. This fixes weird lag more often then people expect.
  6. If the iPad is still slow, back it up and do a full restore with a computer. A clean reinstall beats years of update cruft.
For web lag, test another browser once. If both crawl, it’s the device or network. If only Safari crawls, wipe Safari data or keep using somthing lighter.
If you still need to free up space fast, Clever Cleaner is decent for spotting large files and duplicate photos. I’d use it for cleanup, not as a miracle fix. This review is a solid overview of what it does on iPhone, and most of the storage logic applies to iPad too, see how Clever Cleaner helps free up iPhone storage.
Blunt truth, if it has 2GB RAM or less and it’s stuck on an older iPadOS branch, some lag is never going away. At that point a refurb model saves a lot of frustation.
If it’s lagging even when typing, I’d stop thinking “storage only” and start thinking “hardware ceiling + software bloat.” @mikeappsreviewer and @nachtschatten already covered cleanup/reset stuff, so I’d look at one thing people skip: heat.
Old iPads slow down hard when they run hot. Take the case off, charge it less while using it, and see if performance improves after 15 to 20 mins idle. Sounds dumb, but it matters.
Also check this:
  • Mail app with too many accounts can bog older iPads down
  • Thousands of Safari tabs can absolutely wreck responsiveness
  • Low Power Mode can help a little on older models
  • Turn off unnecessary location access under Privacy
  • Remove giant widget stacks from the home screen
I slightly disagree with the “full restore” advice as the next big step. Sometimes that’s a whole afternoon wasted if the iPad is just ancient and underpowered. First check your model and RAM. Some older ones are simply done.
If you still need space, Clever Cleaner is useful for finding big files and duplicate photos fast. This is a decent demo of it on iOS: see Clever Cleaner speed up iPhone and iPad storage cleanup
Blunt version: if it’s an old base model stuck lagging everywhere after basic tuning, you’re probly at the “refurb upgrade” stage. Not fun, but true.
