I’m having trouble with Quizizz loading properly on my browser. It either takes forever or fails to load entirely. I’ve tried refreshing the page and clearing my cache, but nothing seems to work. Is anyone else experiencing this problem or has a solution? Need help to get it working ASAP for an upcoming quiz session.
Have you tried disabling browser extensions? Sometimes extensions can mess with how websites load. Ad blockers are notorious for this kind of issue. Another thing you could try is using a different browser, just to see if the problem persists there. I had a similar issue with Quizizz on Chrome, but it worked fine on Firefox. Also, check your internet connection. Seems obvious, but a flaky WiFi can cause loading issues. If nothing else works, you might want to clear your DNS cache; in Windows, open Command Prompt and type ipconfig /flushdns. It might do the trick.
Folks here have also suggested that making sure your browser is up to date could solve this. Browser updates sometimes fix bugs that can cause these kinds of problems.
Additionally, consider turning off your hardware acceleration in your browser settings, as it has been known to cause compatibility issues with some web apps.
Lastly, it’s worth noting that Quizizz might be having server issues. It’s rare, but it happens. You can check their status on websites like Downdetector to see if others are experiencing the same issues.
Good luck!
Sometimes, the issue could be as simple as your browser needing a restart. Here’s another approach: try disabling any proxy settings you might have. It can interfere with how web pages load. Also, check if your firewall isn’t blocking Quizizz. Firewalls or antivirus software sometimes flag websites incorrectly.
If you’re on a school or workplace network, it’s possible there are network restrictions in place; you might want to check with your network admin.
One other thing that really helped me once was resetting my browser settings to default. This can clear out some hidden settings that you might’ve unknowingly tweaked. Just be aware that you’ll lose any custom settings or shortcuts you have.
Another user mentioned trying different browsers. If you’ve already done that, try incognito mode. Incognito mode might bypass any troublesome extensions or cache that could be affecting the page load.
Lastly, if it’s a recurring issue that none of these solutions fix, it might be worth reaching out to Quizizz support directly. They might be aware of specific, ongoing issues or can provide a more granular fix.
And btw, @viajeroceleste’s suggestion about checking Downdetector is a good shout. Sometimes it’s not your fault at all, and knowing others are facing the same problem can save you some headache.
Hope some of these help! Let us know if anything works.
Hey, something else you might wanna try is checking your JavaScript settings. If JavaScript is disabled, Quizizz won’t load properly since the site heavily relies on it. Just go to your browser settings and make sure JavaScript is turned on.
Another angle to consider: check the device’s date and time settings. Incorrect date/time settings can cause SSL errors which may prevent the page from loading.
Also, it might be worth doing a quick malware scan. Sometimes, malicious software can interfere with how websites load. Running a scan with your antivirus software, or even a dedicated malware removal tool, could uncover hidden issues.
Pros for this extra step:
- Ensures security and removes any potential threats to your system
- Could solve loading issues if malware was the cause
- The scan process can take some time
- Might require additional tools if your current software doesn’t cover it
Something else that worked for me once: changing the DNS server settings to use Google’s DNS (8.8.8.8 and 8.8.4.4) or Cloudflare’s DNS (1.1.1.1). Sometimes, your ISP’s DNS servers might be slow or experiencing issues.
And I do agree with @viajeroceleste on updating your browser. It’s a crucial step often overlooked. On the flip side, don’t ignore that sometimes updating can bring in new bugs. It’s always a bit of a gamble.
Lastly, if you’re on a VPN, try disabling it. VPNs can sometimes cause delays or loading issues with certain sites, including Quizizz.
Hope at least one of these steps help! ![]()
Try a different browser profile or a guest window.
On Chrome
- Click your profile icon.
- Choose Guest or add a new profile.
- Open Quizizz there and log in.
This skips your old extensions, cookies, and settings in one move. If Quizizz loads fine, the issue sits in your original profile. Then you narrow it down later, but at least you run your quiz now.
