Need help choosing the best Mac data recovery software
I accidentally deleted important files on my Mac and emptied the Trash before I realized what was missing. I need reliable Mac data recovery software that can recover documents and photos without causing more data loss. Looking for real recommendations on the best data recovery software for Mac right now.
Mac recovery stuff I kept coming back to
I tried a pile of Mac data recovery apps over the last few years. I still ended up pointing most people to Disk Drill. Not because it wins every single case. It doesn’t. I kept using it because it lands in a useful middle spot. The recovery rate was good enough for real messes, the layout didn’t fight me, and it behaved well on newer Macs.
A lot of recovery apps go one of two ways. They either feel stripped down and weak, or they dump you into a screen full of options with no plain explanation. Disk Drill sits between those two.
What stood out to me
It feels built for macOS instead of ported over as an afterthought. I noticed a few things right away:
  1. It handles APFS properly.
  2. It runs fine on Apple Silicon.
  3. It reads external SSDs, SD cards, USB drives, and Time Machine volumes without much drama.
  4. The file preview feature was useful, not fake-useful.
  5. It includes backup and disk image tools, which mattered on shaky drives.
I had one APFS volume go bad after an external enclosure started dropping out. Some tools saw almost nothing. Disk Drill pulled a decent chunk of the directory and gave me previews before recovery, which saved time and guesswork.
Why I kept it in rotation
Here’s the short version:
  1. Solid results on deleted files and formatted drives
  2. Previews I could trust before restoring
  3. Built-in imaging for unstable disks
  4. Good support for photo and video formats, including RAW files
  5. Easier to work with than most of the heavier recovery apps
Other Mac recovery tools I’d still bother with
The ‘best’ option changes with the job. I wouldn’t pretend one app fits every failure.
PhotoRec
Free, ugly, effective. I used it a few times on damaged SD cards and trashed file systems. It found more than I expected. The cost is organization. You usually lose original filenames and folder structure, so you get a pile of recovered files dumped out like laundry on the floor. Still worth it when the alternative is zero files.
iBoysoft Data Recovery
This one felt easier for newer users. APFS support seemed decent in my tests, and the workflow was simple enough if you don’t want to spend an hour reading menus. My gripe was the subscription model. I don’t like paying ongoing fees for a tool I might need once after a bad day.
Data Rescue
Older tool, still useful in some cases. I wouldn’t reach for it first every time, but I’ve seen it do fine on external drives and less messy recovery jobs. If the issue is straightforward, it still has a place.
The part people mess up
The biggest mistake happens before the scan even starts. Once files vanish, stop using the drive.
I mean it. Don’t keep saving stuff to it. Don’t install apps onto it. Don’t keep rebooting and poking around if you have another option. On SSDs, TRIM makes this worse. Deleted data on modern Macs can disappear fast, for good.
What I’d do first
  1. Install the recovery app on a different drive if you have one
  2. Restore recovered files to another drive, not back onto the same disk
  3. Clone unstable drives before running repeated scans
  4. Skip random repair tools until your files are safe
I’ve seen recoveries fail because the person kept using the Mac like nothing happened for another day or two. By then, the drive had overwritten enough blocks to make recovery way harder, or flat out dead.
My plain answer
If someone wanted one low-drama recommendation for Mac recovery, I’d still say Disk Drill.
If you know your way around recovery tools, or you’re dealing with a weird case, one of the others might fit better. But for most people trying to get files back without turning it into a weekend project, Disk Drill is the one I kept coming back to.
If the files were on your internal Mac SSD, time matters more than brand names. Stop writing to that drive. TRIM on Apple SSDs wipes deleted blocks fast, so recovery odds drop every minute you keep using it.
My pick is Disk Drill for this case. Not because it wins every test, and I disagree a bit with @mikeappsreviewer on one point, I would not call it the middle option anymore. On Mac, it is one of the safer first tries because the preview is solid and the scan flow is hard to mess up. That matters when you already emptied Trash and do not want a second mistake.
Short list:
  1. Disk Drill, best first choice for deleted docs and photos on macOS
  2. R-Studio, stronger for advanced cases, harder UI
  3. PhotoRec, free, messy file names, last-resort tool
Do this:
  1. Install the app on an external drive
  2. Scan the Mac drive in read-only mode if offered
  3. Recover to another drive, not the same one
  4. If the drive seems unstable, image it first
If you want a quick walkthrough, this best Mac recovery software video guide is easy to follow.
If Time Machine was on, check snapshots first. People skip taht step way too often.
Emptying Trash on a Mac is not automatic game over, but I’d be a little less relaxed than @mikeappsreviewer and @codecrafter if the files were on the internal SSD. On modern Macs, TRIM can make deleted docs/photos vanish faster than people think, so the “best software” also depends on where the files lived.
My take:
  1. If it was the internal Mac drive
    • try recovery immediately
    • stop using the Mac as much as possible
    • if you have another Mac, create a bootable external or work from external storage
  2. If it was an SD card, USB drive, or external HDD/SSD
    • your odds are usually better
    • software recovery is way more realistic
For software, Disk Drill is still the first one I’d try for Mac data recovery, mostly because it’s less likely to make a bad situation worse for a normal user. The reason I rank it high is not just the scan results, but the fact that it lets you inspect what it found in a pretty sane way before restoring. That matters a lot with documents and photo libraries.
Where I slightly disagree with the others: I would not jump straight to PhotoRec unless you’ve accepted chaos. It’s powerful, sure, but for mixed personal files it can turn recovery into a sorting nightmare. Great for “recover anything possible,” not great for “I need these family photos and tax PDFs by tonight.”
Also, before buying anything, check:
  • iCloud Drive recently deleted
  • Photos app recently deleted
  • Time Machine
  • local snapshots if Time Machine was enabled before
This Apple thread is actually worth skimming for backup and file recovery ideas:
Apple forum tips for recovering deleted files on Mac
Short version: Disk Drill is probably your best first shot, especially for deleted documents and photos on macOS. If the drive is failing physically, skip the DIY hero stuff and image it first, becuase repeated scans can make things worse.
