Need help refining my software testing strategies
I’m working on a small project and my current software testing strategies feel random and inefficient. I’m not sure how to structure unit tests, integration tests, and regression tests so they actually catch real-world bugs before release. Can someone walk me through practical, step-by-step testing approaches or best practices that a solo dev or small team can realistically follow?
Yeah, “random and inefficient” testing smells like you have no clear levels or goals. Here’s a simple structure you can stick to and grow from.
  1. Start with a test pyramid
Top to bottom:
  • End to end tests: few, slow, run on CI only.
  • Integration tests: some, medium speed, run on CI.
  • Unit tests: lots, fast, run on every local change.
Default ratio: about 10 unit tests for 1 integration test for 0.5 end to end tests. Not a rule, just a sanity check.
  1. Unit tests: test behavior, not internals
Goal: protect logic in a single module or class.
Guidelines:
  • One unit under test.
  • No network or database or filesystem.
  • Use mocks or stubs for dependencies.
  • Each test should hit one behavior and one main assertion.
Good unit test pattern:
  • Given: initial state and inputs.
  • When: call the function.
  • Then: assert output and maybe key side effects.
Example structure:
  • happy path
  • invalid input
  • boundary cases
  • weird edge conditions you hit in prod
If a test needs real DB or HTTP, move it to integration.
  1. Integration tests: test wiring between components
Goal: ensure modules talk to each other correctly.
Typical targets:
  • Service + DB
  • Service + external API (with test doubles if possible)
  • HTTP routes + controller + domain layer
Guidelines:
  • Use real DB, but isolated. For example test DB per run, or migrations per test class.
  • Seed minimum required data.
  • Assert both data and behavior. Example: HTTP 200, response body, record stored.
Keep integration tests fewer and more focused:
  • Critical flows only.
  • High risk code.
  • Past bug areas.
  1. Regression tests: bugs first, tests second
Process for regression:
  • Bug reported.
  • Reproduce in a failing test.
  • Fix code.
  • Keep the test so it stays green next time.
Rule: no bug fix without a failing test first. If you cannot write a test for it, your code boundaries are weird. That is a signal to refactor.
Good regression test pattern:
  • Use test name with the bug reference. Example: test_cancels_order_after_payment_timeout_bug_1342.
  • Put it in the closest level that can express the bug:
    • Logic bug in a formula: unit test.
    • Wrong DB query: integration test.
    • Whole flow broken: end to end or API level test.
  1. How to pick what to test
Stop testing random stuff. Use these filters:
  • Critical paths:
    • Login
    • Payments
    • Data writes
    • Key workflows users hit daily
  • Risky code:
    • Complex conditionals
    • Code with many dependencies
    • Code people touch often
  • External behavior:
    • Public methods
    • Public HTTP endpoints
    • Events and messages
If you need a starting point, list your 3 most important user flows and write at least:
  • 1 end to end test per flow.
  • 3 to 5 unit tests per core function in that flow.
  • 2 to 3 integration tests for DB or API parts.
  1. Test data strategy
Random test data tends to hide bugs instead of exposing them.
Use:
  • Minimal data needed.
  • Named builders or factories. Example: make_paid_order(), make_unpaid_order().
  • Hardcoded values that highlight edge cases. Example: boundary dates, zero, negatives, max lengths.
  1. When to run what
  • Unit tests: on every file save or commit. Fast feedback.
  • Integration tests: on every push or PR.
  • End to end and full regression: on main branch or nightly runs.
If your suite gets slow, cull or merge tests. Slow tests become ignored tests.
  1. Smell checks
Watch for these:
  • Tests failing randomly: often due to shared state or time based logic.
  • Fragile tests that break on small refactors: tests know too much about internals.
  • Huge integration tests that assert everything: split into smaller focused tests.
  1. Minimal actionable plan for your small project
Today:
  • Pick 1 module.
  • Write 5 clean unit tests around its public API.
  • Add 1 integration test that touches DB or external API for this module.
This week:
  • Cover your top 2 user flows with:
    • 1 end to end per flow.
    • A handful of unit tests for core logic.
    • A few integration tests where things connect.
You do not need fancy frameworks to start. You need clear boundaries:
  • Unit = isolated function or class.
  • Integration = real collaborators and infrastructure.
  • Regression = bug story encoded as a test.
Once this structure is in place, your tests stop feeling random and start feeling like a safety net that grows with the project.
You’re not alone on the “random and inefficient” testing vibe. @techchizkid already laid out a solid structural map (pyramid, levels, etc.), so I’ll skip rehashing that and focus on how to actually make those tests feel like they’re doing real work for a small project.
Here’s a different way to think about it: design your tests around decisions and contracts, not just layers.
1. Start from real user scenarios, then decompose
Instead of asking “what should I unit test,” start with 3 to 5 real user actions:
  • “User signs up and confirms email”
  • “User creates an item and sees it in a list”
  • “Admin exports a report”
For each scenario, answer:
  • What decisions does the system make?
  • What external contracts does it rely on?
    Example: “If the input is X, do we decide A or B?”
Those decisions become unit test targets. Those external contracts become integration targets.
That way, your tests map to actual behavior people care about instead of arbitrary functions.
2. Treat each module as a mini API with a contract
Instead of “test all functions,” define what each module promises:
For example, a PriceCalculator might promise:
  • Given a base price and a discount code, returns a final price or an error
  • Never returns negative prices
  • Applies highest priority discount if multiple are valid
Now your unit tests become: “does it fulfill the contract in all notable cases?”
Pattern:
  • Normal / typical use
  • Invalid inputs
  • Boundaries
  • One weird case you’ve actually seen or can imagine
This is slightly different from @techchizkid’s behavior focus because I’m saying: write down the contract first, even informally, then test precisely that. If you can’t describe the contract, that’s a hint your design is muddy.
3. Integration tests: define what you’re NOT mocking
Another angle: instead of “what am I testing,” ask “what am I trusting here?”
Example:
  • If you trust your database library but don’t trust your SQL queries, then integration tests should hit:
    • Your code + real DB engine + your migrations
  • If you trust the third party API spec but don’t trust your integration code, then:
    • Your code + local stub that mimics API responses
Make each integration test answer one very specific question like:
  • “Does creating a user actually write a row with the right columns?”
  • “Does this endpoint call the payment service and store the transaction result?”
Keep them small. 1 behavior, 1 or 2 asserts. If an integration test feels like a whole story with 15 asserts, split it.
4. Regression tests: store actual bug stories
Where I slightly disagree with the “no bug fix without a failing test” rule: on a very small project, sometimes you just need to unbreak prod now. But: after the emergency, the bug should be turned into a documented story with a test.
Good pattern:
  • Have a folder or tag specifically for regression tests (e.g. regression/).
  • Name tests like test_prevent_double_charging_on_retry() instead of generic stuff.
  • Include the context as comments:
    • “Bug: users were charged twice if they refreshed on step 3”
    • “Root cause: idempotency key was not persisted”
Over time this becomes a history of pain that protects you from repeating the same mistakes. It also keeps regression tests from feeling like random scattered checks.
5. Use coverage as a smoke detector, not a goal
On a small project, it’s easy to obsess over code coverage. Instead:
  • Get coverage reports running.
  • Sort by:
    • Critical modules with low coverage
    • Buggy modules with low coverage
  • Add tests there first.
Don’t chase 90%. A function that returns a constant can be uncovered forever and nobody cares. A payment or deletion path at 20% coverage is a problem.
6. Make tests readable enough that “future you” thanks “past you”
You’ll know you’re doing this right if a test doubles as documentation. When you re-open the project 3 months later, can you answer:
  • “How is this supposed to behave?”
  • “What happens when this is invalid?”
  • “Is this edge case intentionally handled or not?”
If the tests answer those questions without reading the source, they’re structured well.
Some quick readability tricks:
  • Use helper functions like create_user(active=True) instead of stuffing raw dicts and SQL in every test.
  • Hide setup noise, keep the assertion visible and clear.
  • Prefer a few well named tests over a monster test with 12 asserts.
7. Concrete minimal setup for your case
Something you can literally do this week:
  1. Write down your top 3 user flows in a txt file.
  2. For each flow, list the decisions and external systems touched.
  3. For each decision:
    • Add 3 to 6 unit tests that capture the contract.
  4. For each external system:
    • Add 1 or 2 focused integration tests that verify you’re talking to it correctly.
  5. Every time you fix a bug:
    • Paste the bug description into a new test’s comment.
    • Add a test that fails before the fix.
If your tests don’t feel random when you explain them to someone (“these cover signup decisions, these cover DB writes, these are old bugs we never want again”), you’re on the right track.
Once you’ve done that, then fancy concepts like pyramids and ratios start to feel natural instead of academic.
