Need help setting up voicemail on my Samsung phone
I just switched to a Samsung phone and can’t figure out how to set up voicemail or access my messages. The prompts are confusing and I’m not sure if it’s a carrier issue or a phone settings problem. Can someone walk me through the exact steps to set up and check voicemail on a Samsung, including any common mistakes to avoid?
This trips a lot of people up when they switch phones, so here is the quick way to sort it out.
First, figure out if the issue is your carrier or your Samsung settings.
  1. Test basic carrier voicemail
  • Open the Phone app.
  • Tap the keypad.
  • Press and hold 1.
  • If it calls voicemail, follow the audio prompts.
  • If it says something like “voicemail not set up” or “call cannot be completed,” it is a carrier issue. In that case:
    • Call your carrier’s support from another phone.
    • Ask them to reset or provision voicemail on your line.
    • Common direct voicemail numbers:
      • Verizon: dial *86
      • AT&T: press and hold 1 or dial your own number
      • T-Mobile: press and hold 1
      • Spectrum / Xfinity etc often use press and hold 1 too
  1. Set voicemail greeting and PIN
    Once you get into the voicemail system by holding 1:
  • It usually walks you through:
    • Create or change PIN.
    • Record your name.
    • Record a greeting.
  • If prompts sound confusing, choose the “skip tutorial” or “advanced options” choice, then listen for “personal options” or “mailbox settings.”
  • If you mess up, you can re-run the setup from the main menu, option like “personal options” or “administrative options.”
  1. Turn on Visual Voicemail on Samsung
    This is on the phone side.
  • Tap the three dots in top right.
  • Tap Settings.
  • Look for Voicemail or Visual Voicemail.
  • If you see Visual Voicemail, tap it and turn it on.
  • If it says something like “Visual Voicemail not supported,” that usually means:
    • Your carrier plan does not include it.
    • Or the carrier app handles voicemail.
  1. Check if your carrier uses its own app
    Some carriers force voicemail through their own app.
  • Look for these in your apps:
    • “My Verizon” or “Voicemail” from Verizon.
    • “AT&T Visual Voicemail.”
    • “T-Mobile Visual Voicemail.”
  • Open that app.
  • Sign in if needed.
  • It should walk you through voicemail setup.
  • If you see errors, clear the app cache:
    • Settings > Apps > [App name] > Storage > Clear cache.
    • Then re-open.
  1. Set voicemail number in Samsung settings
    If holding 1 does nothing or dials the wrong number:
  • Tap the three dots.
  • Tap Settings.
  • Tap Voicemail.
  • Tap Voicemail number.
  • Enter your carrier’s voicemail access number:
    • Verizon: *86
    • T-Mobile: your own phone number, or the voicemail access number from their site.
    • AT&T: your own number or their voicemail number.
  • Save, then press and hold 1 again to test.
  1. Check SIM and network
    Voicemail is tied to your SIM and carrier profile.
  • Make sure mobile data or at least voice signal is strong.
  • Airplane mode should be off.
  • Restart the phone.
  • If you moved your SIM from an old phone and voicemail never worked right since:
    • Call the carrier and ask them to “rebuild” or “reset” your voicemail box.
  1. Quick way to access messages after setup
  • Old style voicemail:
    • Press and hold 1 in the Phone app.
    • Enter your PIN.
    • Listen and manage messages with keypad options.
  • Visual Voicemail:
    • Open Phone app.
    • Tap Voicemail tab at the bottom, or the Visual Voicemail app.
    • Tap a message to listen.
    • Delete or archive from there.
  1. If prompts still feel confusing
    When you hear the voicemail robot:
  • Listen for:
    • “To hear your messages, press 1.”
    • “To change your personal options, press 4” or similar.
  • Common numeric patterns on many systems:
    • 1 = listen to messages.
    • 2 = send a message.
    • 3 = manage greetings.
    • 4 or 5 = personal options or settings.
  • If you get stuck, hang up and call back. The system will not break.
Short checklist to try in order:
  • Press and hold 1.
  • If nothing, set voicemail number in Phone settings.
  • If still broken, call carrier support and ask them to:
    • Enable voicemail for your line.
    • Reset your mailbox.
  • After they fix it, run through the audio setup once more.
  • Then enable Visual Voicemail if supported.
If you reply with your carrier name and Samsung model, people here can give exact menu names and the right voicemail number, since a few of them differ slightly.
Couple of things you can try that aren’t just “hold 1 and pray,” since @suenodelbosque already covered the classic route:
  1. Check if Samsung’s own Visual Voicemail is actually hidden on you
    • Look at the bottom bar. Some Samsung builds have a “Voicemail” tab there that people miss.
    • If you see it, tap it.
      • If it asks you to “Activate” or “Agree,” walk through that.
      • If it spins forever or errors out, that usually means your carrier side isn’t fully set up, even if the basic voicemail number kind of works.
  2. Try calling your own number instead of holding 1
    • Dial your own phone number from your Samsung.
    • When your greeting starts, hit * or # (varies by carrier).
    • That should drop you into the mailbox menu.
    • If nothing like that happens and it just leaves a message, your voicemail might not exist yet on the carrier side.
  3. Check if call forwarding is hijacking voicemail
    Sometimes voicemail is “broken” because unanswered calls are forwarded somewhere weird.
    • Open Phone app → 3 dots → Settings.
    • Tap “Supplementary services” or “More settings” (depends on model/carrier).
    • Tap “Call forwarding.”
    • Look at:
      • When busy
      • When unanswered
      • When unreachable
    • They should point to a carrier number or your voicemail number.
    • If they point to some random number or are blank, that can mess things up. You can usually tap “Disable” or “Reset to default.”
  4. Check if your phone is using the wrong SIM profile
    • If you’re on dual SIM or eSIM:
      • Settings → Connections → SIM manager.
      • Make sure the SIM with your actual service is set as the default for calls.
      • Go back to Phone → Settings → Voicemail and confirm it is tied to that same SIM.
  5. Carrier “features” that break stuff
    Some carriers have add‑ons like call forwarding services or “advanced voicemail” that conflict with Samsung’s Visual Voicemail.
    When you call support, don’t just say “voicemail isn’t working.” Say:
    • “Please verify my voicemail is provisioned correctly.”
    • “Remove any old voicemail profile from my previous phone if it’s still attached.”
    • “I’m using a Samsung [model]. Does my line support Visual Voicemail on Samsung, or only via your app?”
      A lot of reps will just say “Try turning it off and on” unless you ask specific things.
  6. If the prompts are confusing
    Instead of trying to do everything in one call:
    • First call: just set PIN and get to where you can actually hear messages. Ignore greeting/name if it’s too much.
    • Hang up.
    • Second call: go into “personal options” or “mailbox settings” and change greeting once you know which menu numbers do what.
      Also, jot down the key you press:
    • Whatever number plays messages
    • Whatever number gets into personal options
      After that, you don’t have to listen to the full spiel every time.
  7. Quick test to figure out if it’s you or them
    • Call your number from another phone.
    • Let it ring until it times out.
    • Watch what happens:
      • If it never goes to voicemail at all, that’s almost always a carrier provisioning / call forwarding issue.
      • If it goes to a generic mailbox that doesn’t know you, your line might be mapped to the wrong mailbox.
      • If it goes to voicemail fine, but you can’t access messages from your Samsung, then it’s mostly a phone/config issue.
If you drop your carrier and exact Samsung model, people can usually say “tap X then Y” with the exact names and also confirm the right voicemail access number, since some of them use weird region-specific ones and not just *86 or “your own number.”
Skip the confusing prompts for a second and use this as a quick “what exactly is broken?” checklist:
  1. Figure out which of these three situations you are in
    • Calls never reach voicemail at all.
    • Callers reach voicemail, but you cannot listen from your Samsung.
    • Visual voicemail list is empty or missing, even though basic voicemail works.
    Each one points to a different fix, so don’t treat them as the same problem.
  2. If calls never hit voicemail
    @ombrasilente and @suenodelbosque already walked through carrier setup and the usual “press and hold 1” route. Where I’d do something slightly different is: get a friend’s phone, call your number, and time it.
    • If it rings 30+ seconds then just drops, your “no answer” forwarding timer or destination is likely wrong.
    • Ask your carrier to:
      • Confirm the “no answer” forward target is your actual mailbox.
      • Shorten or lengthen the ring time to something normal (20 to 25 seconds).
        This is a carrier-side flag, not a Samsung setting.
  3. If voicemail works, but Samsung acts weird
    Instead of wrestling with audio menus, use the phone’s own indicators to see what is wired correctly:
    • Put the phone in Airplane mode, wait 10 seconds, turn it off.
    • After signal comes back, leave yourself a voicemail from another phone.
    • Watch for:
      • A voicemail notification icon in the status bar.
      • A missed-call + voicemail combo in the call log.
        If you get the notification but no way to open it, that almost always means Samsung’s dialer and the carrier’s voicemail app are fighting. In that case:
    • Pick one system and stick with it:
      • Either uninstall/disable the carrier’s voicemail app and use Samsung’s native Visual Voicemail.
      • Or turn off Visual Voicemail in the Phone app settings and rely only on the carrier’s app.
        Mixing both is where people often get stuck.
  4. Ignore the tutorial the first time
    I actually disagree a bit with trying to “follow all the prompts” carefully on day one. The tutorials are long and confusing.
    Better pattern:
    • First call: only set a PIN and confirm you can press 1 to listen to new messages.
    • Second call (later): go back in and change greeting and recorded name once you know which key gets you into “personal options” on your carrier.
      That way you are not lost in a 5 minute script you will never want to hear again.
  5. Visual voicemail specific problems
    When Visual Voicemail is half working, you might see:
    • Old messages but no new ones.
    • “Unable to sync” or “Can’t connect to voicemail” errors.
      Targeted fixes that often help more than generic resets:
    • Turn off Wi Fi briefly and force it to sync on mobile data. Some carriers require that for voicemail provisioning.
    • Check Data Saver or battery optimizations:
      • Settings → Apps → Phone (and any carrier voicemail app) → Battery → allow it to run in background.
        Visual voicemail is basically a tiny data client. If Android throttles it, voicemail never downloads.
  6. When to stop tweaking and call the carrier
    You have hit the “stop poking settings” point if both are true:
    • Holding 1 does not reach a mailbox that knows your number.
    • Calling your number from another phone does not land in a proper mailbox with your greeting (or any greeting).
      At that point, Samsung settings are not the bottleneck. You need the carrier to:
    • Delete / rebuild your mailbox profile.
    • Reprovision voicemail after your phone switch.
      Tell them clearly: “Voicemail is not provisioned correctly on my line at all, not just visual voicemail.” That wording usually gets them to check the right systems.
  7. About the “product title” you mentioned
    You referenced ', which looks like a placeholder rather than an actual voicemail app or tool.
    Pros if this were a real voicemail helper app or guide:
    • Could centralize step by step setup instead of making you hop through carrier menus.
    • Might give clear, on screen explanations of each voicemail option.
    • If it is just documentation, it still cannot fix carrier provisioning.
    • Extra app or guide adds one more place to look, which some people find more confusing than just using the Phone app + carrier support.
      Competitor wise, what @ombrasilente posted is more of a structured troubleshooting flow, while @suenodelbosque focused on extra edge cases like call forwarding and dual SIM. A real product in this space would basically be trying to bundle what both of them explained into a single, friendlier interface.
  8. Quick “what should I do right now?” summary
    • Call your own number from another phone and see what actually happens.
    • If it never goes to voicemail, contact your carrier and say “please rebuild and reprovision my voicemail box” before touching more Samsung settings.
    • If it does go to voicemail, but your Samsung cannot get in or sync, pick one method only: native Samsung Visual Voicemail or the carrier voicemail app, not both, and disable battery / data restrictions for whichever you use.
If you add your country, carrier, and exact Samsung model, folks can usually tell you whether you should be using Samsung’s built in voicemail tab or a specific carrier app and what the right access number is for holding 1.
