I’m trying to figure out how to properly set up and use Opendream Ai for my creative projects, but I’m confused by the options and lack of clear instructions. Can someone explain the basic setup steps, best settings, and any common mistakes to avoid so I don’t waste time experimenting blindly
Short version on getting started with Opendream AI, so you can get work out of it fast instead of clicking random buttons forever.
I’ll assume you are using the web version, not a local install.
- Basic setup
- Make an account and verify email.
- Go to the “Image” or “Generate” tab.
- Pick a model. Start with their default “Opendream” or “SD 1.5 style” type model. Those are easier to control than the more “artsy” ones.
- Set image size to something like 768x1024 or 1024x1024. Bigger images use more credits and tend to be slower.
- Prompt basics
- Positive prompt: describe subject, style, and lighting.
Example: “portrait of a young woman, soft light, 35mm photography, natural skin, subtle colors” - Negative prompt: what you do NOT want.
Example: “blurry, extra limbs, distorted face, text, watermark” - Keep first tests short and clear. Add style words after you get a decent base.
- Core settings that matter most
Names differ a bit per UI, but the logic is the same as Stable Diffusion.
Steps:
20–30 steps is a good default.
More steps give slightly more detail but increased time. Diminishing returns after ~30 for most art. -
CFG scale / Prompt strength:
Usually around 5–8 works.
Lower (3–5) gives looser adherence to prompt and more “creative” output.
Higher (9–12) follows your words more closely but often looks stiff or overbaked.
Start at 7. Adjust if results look off. -
Sampler:
If you see options like “DPM++ 2M”, “Euler a”, “DDIM”, pick one and stick to it at first.
For many users DPM++ 2M or Euler a gives clean and consistent results.
Only experiment later. The difference is rarely huge for beginners. -
Seed:
If there is a “random” toggle, leave it on when exploring.
When you like one image, copy its seed and reuse it to get variations with small prompt changes.
- Practical workflow for creative projects
Step 1: Rough concepts
- Use lower resolution, like 512x768.
- Steps 20, CFG 7, random seed.
- Generate 4 images at a time if the interface allows it.
- Focus only on composition and vibe, do not worry about small defects.
Step 2: Refine the best one
- Pick the best result and upscale or re-generate it at higher resolution.
- Keep same seed.
- Add detail words: “detailed eyes, realistic lighting, sharp focus, clean lines” etc.
- Tighten negative prompt if you see repeated issues like “extra fingers, messed-up hands, noisy background”.
Step 3: Fix problems
- Use inpainting / masking if Opendream offers it.
Example: mask the hands and re-generate them with a prompt like “anatomically correct hands, 5 fingers, natural pose”. - For faces, try a “face fix” or “restore face” toggle if there is one.
- Best “starter” settings summary
- Resolution: 768x1024 or 1024x768.
- Steps: 25.
- CFG: 7.
- Sampler: DPM++ 2M or Euler a if listed.
- Batch size: 2–4 images.
- Prompt structure:
“[subject], [style], [lighting], [mood]” - Negative prompt template:
“blurry, low resolution, distorted face, extra limbs, extra fingers, text, watermark, signatures, bad anatomy”
- Typical problems and quick fixes
Problem: Faces look strange.
Fix:
- Add “detailed face, symmetrical face, natural skin” to positive prompt.
- Add “mutated face, deformed face, disfigured” to negative prompt.
- Use more steps (30) and slightly lower CFG (6–7).
Problem: Hands are messed up.
Fix:
- Add “extra fingers, bad hands, disfigured hands” to negative prompt.
- Inpaint the hand area if the tool supports it instead of redoing the whole image.
Problem: Output ignores your style words.
Fix:
- Move style words earlier in the prompt.
- Lower CFG if it looks too rigid.
- Try a different model tuned for that style, like “anime”, “photo”, or “illustration” presets if Opendream has them.
- Simple test prompt set you can try
Realistic portrait:
Positive: “close-up portrait of a woman in her twenties, 35mm photo, soft natural light, realistic skin, subtle makeup, shallow depth of field, background slightly blurred”
Negative: “blurry, oversaturated, cartoon, extra limbs, extra fingers, distorted face, text, watermark, noisy background”
Stylized illustration:
Positive: “full body character, fantasy armor, dynamic pose, digital illustration, clean line art, flat colors, simple background”
Negative: “photo, realistic skin, 3d render, noisy, low contrast, text, watermark, overlapping limbs”
- Save your working combos
When you get a result you like, write down or screenshot:
- Model name
- Steps
- CFG
- Sampler
- Resolution
- Prompt and negative prompt
Reuse that combo for similar projects and tweak from there.
If you share which exact settings you see in your Opendream panel, people can help you dial them in even tighter.
Couple of extra angles to add on top of what @kakeru already laid out:
- Start from the result you want, not the settings
Instead of hunting for “best settings,” decide first:
- Is this for print, web, or just sketching ideas?
- Print: higher res (like 1024x1536 or more), but generate small first, upscale later.
- Web / concept: you can stay at 768x1024 most of the time.
- Photo-ish, anime, or painterly? Pick the model that matches that, then stick to it for a session so you’re not changing 5 variables at once.
- Use presets & save your own
If Opendream has presets like “Photo,” “Anime,” “Concept art,” use those at the start.
Once you get a result you like, treat it as a preset:
- Reuse the same model, steps, CFG, sampler.
- Only change the subject part of your prompt.
This is way faster than chasing “optimal” settings every time.
- Iterate with small changes
Where I slightly disagree with @kakeru: I’d avoid overloading negative prompts too early. A giant negative list can make things stiff and weird.
Try this pattern instead:
- First run: super simple negative prompt: “blurry, text, watermark, extra limbs.”
- Look at what’s wrong.
- Only add 1–2 new negative terms per iteration, based on actual issues you see.
This keeps you from fighting the model with a wall of conflicting instructions.
- Use “prompt blocks” like Lego
Make tiny reusable chunks you can copy/paste:
- Lighting block: “soft cinematic lighting, subtle shadows, volumetric light”
- Detail block: “highly detailed, crisp edges, clean rendering”
- Mood block: “moody, dramatic, dark color palette”
Then your prompt becomes:
“main subject, style words” + lighting block + detail block + mood block
Way easier than rewriting from scratch every time.
- Lock in composition early
If you care about composition (camera angle, framing):
- Put that stuff at the front of the prompt:
“wide shot, dynamic angle, full body, standing on cliff, fantasy landscape, digital painting…” - Once you get a composition you like, copy the seed and only tweak style/lighting.
Think of seed as your “camera position” bookmark.
- Make a “starter recipe” for yourself
Here’s a simple all-purpose recipe that’s worked consistently for me in tools similar to Opendream, you can adapt it there:
- Model: whatever general-purpose / realistic base model they have
- Resolution: 768x1152 for vertical, 1152x768 for horizontal
- Steps: 24
- CFG: 6.5
- Sampler: whatever modern sampler they recommend, then don’t touch it for a while
- Positive prompt structure:
“[camera / composition], [subject], [style], [lighting], [mood], [detail block]” - Negative: start tiny:
“blurry, low quality, text, watermark, extra limbs”
Then only change ONE of these at a time. If you move three knobs and the image breaks, you have no idea which one was the problem.
- Quick debugging checklist
When stuff looks “off,” ask yourself:
- Did I change too many things between runs?
- Did I switch models without adjusting my style words?
- Are my style words fighting each other? (e.g. “flat colors, hyper realistic photo”)
- Is CFG super high? If yes, try dropping it by 1–2 before anything else.
If you post a screenshot of your current panel (blur out anything sensitive) and one example result, people can usually tell you in 2–3 tweaks what to change.
You already got solid “which buttons to press” advice from @stellacadente and @kakeru, so I’ll skip repeating that and focus on how to actually get consistent creative results out of Opendream AI rather than just pretty accidents.
1. Treat Opendream AI like a collaborator, not a vending machine
Instead of “type long prompt, hit generate,” try a loop:
- Draft a short prompt (1 line).
- Generate 4 images.
- Pick the closest one.
- Edit only one of these between each run:
- a few words in the prompt
- the seed
- the model
If you change model + CFG + prompt + resolution at once, you can’t learn what’s working. I actually disagree a bit with the huge negative prompts people throw in. Start tiny and add only what the image shows as a problem.
2. Build a personal “prompt kit” instead of chasing best settings
Create a text file (or notes doc) with reusable blocks:
Subject blocks
- “character concept, full body, standing, facing camera”
- “wide landscape, sweeping view, tiny figure in distance”
Style blocks
- “digital painting, soft brushwork, painterly”
- “cinematic photography, shallow depth of field”
Lighting blocks
- “overcast soft light”
- “dramatic rim lighting, strong contrast”
Your Opendream AI prompts then become Lego:
[subject block] + [style block] + [lighting block] + any special details
This is faster than rewriting story-like prompts every time and plays very nicely with the settings recipes that @stellacadente and @kakeru described.
3. Lock your “house style” for a project
For a multi-image project (comic, visual novel, product line), do this:
- Pick one model and stick to it for the entire project.
- Fix a base resolution, steps, CFG, and sampler.
- Save that combo as your “project preset.”
Only change:
- subject words
- pose / composition words
- colors / mood
This avoids the common problem where page 1 and page 10 look like they came from different universes.
4. Composition first, detail later
For Opendream AI, a practical path:
Composition pass
- Lower resolution
- Fewer steps
- Simple prompts: focus on camera angle / pose / layout
- Ignore bad faces and hands
Detail pass
- Same seed and model
- Higher resolution
- Add detail-related words and more specific negatives only for the defects you saw
Polish pass
- Use inpainting / masks for problem spots
- Very short, targeted prompts for those areas
This layered workflow is much more predictable than cranking all the dials on a single run.
5. When Opendream AI acts stubborn
If the output keeps ignoring you:
- Check for conflicting words
- “flat color” vs “hyper realistic photo” in the same prompt will confuse any SD-based tool.
- Drop CFG a bit
Sometimes lower CFG frees the model to follow the “spirit” of the prompt better. - Align the model with the style
If you use a “realistic” model for anime-style art, you are fighting the base training.
6. Pros & cons of using Opendream AI for creative projects
- Web based, so you avoid local GPU setup pain.
- Stable Diffusion style controls, so most SD tutorials translate pretty well.
- Prompt / negative prompt system gives a lot of control once you build your own blocks.
- Good for rapid ideation with seeds and batch generation.
- UI can feel crowded and confusing until you lock in your own preset.
- Documentation and “official” guidance is thinner than some competitors.
- Some advanced tricks from other SD UIs might not map 1:1.
- Quality can vary a lot between models, which is rough if you’re swapping models too quickly.
7. How to use others’ advice without getting lost
@stellacadente focused more on strategic workflow and presets.
@kakeru broke down specific starter settings.
Instead of mixing every tip:
- Choose one person’s full recipe as your baseline.
- Keep it exactly as-is for one evening session.
- Only add one new idea at a time from the other person (for example, prompt blocks, or changing how you use negatives).
After 2 or 3 nights like that, you’ll start to feel how Opendream AI “thinks,” and at that point the settings stop being mysterious and start being just tools.
If you want targeted advice next, post:
- screenshot of your settings panel
- 1 image you like and 1 you hate
- the exact prompts for both
From there it’s usually just 2 or 3 small tweaks to make it behave the way you want.
