Need help with One UI 8.5 update issues
I updated to One UI 8.5 and started running into problems right away. A few features are not working like before, and some settings seem to have changed on their own. I need help figuring out if this is a known One UI 8.5 issue, a bug after the update, or something I can fix with the right steps.
Yep, this happened to a lot of people after big Samsung updates.
Start with the quick fixes.
  1. Wipe cache partition.
    Power off phone.
    Hold Volume Up + Power.
    Enter recovery.
    Pick Wipe cache partition.
    Reboot.
  2. Run Galaxy App Booster.
    Open Good Guardians.
    Run App Booster once.
    This fixes lag, battery drain, and weird app behavior for some users.
  3. Check reset permissions.
    Go to Settings, Apps, choose problem apps.
    Look at battery, notifications, fullscreen, background data, and permissions.
    Updates sometiems flip these.
  4. Recheck One UI settings.
    Look at:
    Home screen layout
    Navigation bar
    Lock screen notifications
    Battery optimization
    Modes and Routines
    Default apps
    Samsung likes to move stuff around after updates.
  5. Update Galaxy Store apps too.
    A lot of Samsung features depend on Galaxy Store plugins, not only Play Store apps.
  6. If stuff is still broken, reset settings.
    Settings, General management, Reset, Reset all settings.
    This keeps your data.
If the phone got worse right after 8.5, wait for the first patch too. Samsung often fixes early bugs in the next build. If you post your model and what features broke, people here can narrow it down fast.
Not gonna fully agree with @kakeru on the “just wait for the first patch” part. Sometimes yeah, Samsung fixes it fast. Other times you wait a month and realize one setting got silently changed and that was the whole problem.
A few things I’d check that are different from the usual cache/reset advice:
  • Test in Safe Mode. If the issue disappears, it’s probably not One UI itself but some app/service conflict after the update.
  • Check device care for sleeping/deep sleeping apps. Updates love shoving apps into those lists and then widgets, sync, notifcations, and background tasks stop working.
  • Re-add Samsung account and Google account sync if contacts, calendar, gallery sync, or backup stuff got weird.
  • If gestures, edge panels, fingerprint, camera features, or AOD changed, look for module/plugin updates in Galaxy Store and Good Lock modules. Those break a lot after major updates.
  • Verify your CSC/carrier build if you have a carrier model. Some “missing features” are actually carrier-disabled after the update.
  • Use Members app and search your exact issue. If lots of reports match your model/build number, then yeah, it’s a known bug and not just your phone.
Post your exact model, carrier/unlocked, and the build number. “One UI 8.5 broke stuff” is kinda too broad tbh.
I’d split this into two buckets: actual One UI 8.5 bugs vs post-update reconfiguration. @kakeru is right that build/model matters, but I wouldn’t assume carrier stuff is the main culprit unless you already noticed missing toggles or network features.
A few checks I’d do that are different:
  1. Reset app preferences
    This does not delete data, but it re-enables disabled system apps and restores default permissions behavior. After major updates, odd stuff can come from one blocked system component.
  2. Recheck battery optimization per app
    Not just sleeping apps. Open the apps that are failing and set them to Unrestricted if they need background activity.
  3. Review notification categories
    One UI updates sometimes keep the app installed but silently change channel-level notifications. So messages, alarms, or reminders look “broken” when only one category got turned off.
  4. Toggle RAM Plus and reboot
    Sounds unrelated, but some users get stutter, reloads, and app instability after updates until memory settings are changed once.
  5. Rebuild biometric settings
    If fingerprint or face unlock is flaky, delete and re-add them. Major updates can keep old enrollment data but mess with response time.
  6. Check default apps
    Browser, caller ID/spam app, launcher, assistant, SMS app, and home app sometimes get reassigned.
Pros of waiting: easy, no risky changes, first patch may fix real bugs.
Cons: if it’s a settings migration issue, waiting does nothing.
If you want useful answers, post: exact phone model, current build number, what broke, and whether it happens on Wi-Fi, mobile data, or both.
