Need Help With the Amazon Fire TV Remote App on iPhone
The Amazon Fire TV Remote app on my iPhone suddenly stopped connecting to my Fire TV, even though both devices are on the same Wi-Fi network. I’ve already restarted the app, phone, and Fire TV, but it still won’t pair or control anything. I need help figuring out why the iOS Fire TV Remote app is not working and what to try next.
If you want an iPhone app for controlling a Fire TV, I tried a few of the usual ones. The one I kept going back to was the simple one.
TVRem – Universal TV Remote App
This one felt the least annoying. I installed it, paired it over Wi Fi on the same network, and it got straight to the point. No wandering through extra tabs, no pile of content panels when all I wanted was to pause a show or type a search.
Why I ended up using it for Fire TV:
Works with Amazon Fire TV and Fire Stick.
It also handles other TVs and boxes, like Android TV, LG, and Samsung.
Pairing over Wi Fi was quick on my setup.
The touchpad felt smoother than apps stuck with only directional buttons.
It has the full remote set, home, back, volume, input, and playback controls.
There’s a built in keyboard, which saved me from pecking out titles one letter at a time.
Everything was available without hitting a paywall when I tested it.
What stood out to me was the feel. It behaved more like a normal remote replacement, less like a bloated companion app.
Official Amazon Fire TV app
I used the Amazon one too. It works. You get navigation, voice search, text entry, and playback controls. No issue there. My problem was the app felt tied to the rest of Amazon’s stuff, recommendations, account pieces, browsing layers. If you want all of it in one place, fine. If you want your phone to act like a remote and get out of the way, it felt heavier than I wanted.
TV Remote – Universal Remote
This one also supports Fire TV. It did the job, sort of. Still, it came off more like a generic universal remote app made to cover everything without feeling great on any single device. On my end, it felt less polished for daily Fire TV use, and the ad or upgrade nudges got old fast.
My take:
The Amazon app is okay if you want something tied into Amazon’s system. For plain day to day control, TVRem felt easier to live with. Faster to open, simpler to use, stable in use, and closer to what I wanted from a Fire TV remote replacement.
Same Wi-Fi is only part of it. Fire TV remote pairing breaks a lot when the network splits devices in ways the router UI does not show well.
Try these checks.
  1. Turn off VPN, iCloud Private Relay, and any security app on your iPhone. Those block local device discovery more often than people think.
  2. Check your router bands. If your phone is on 5 GHz and Fire TV is on a guest, mesh, or isolated node, the app often fails even if the SSID name matches. Guest mode is the big one.
  3. On iPhone, go to Settings, Amazon Fire TV, then enable Local Network. If that got toggled off after an iOS update, pairing dies.
  4. On Fire TV, forget the Wi-Fi network, reconnect, then go to Settings, Network, and confirm it shows the same subnet as your phone. Example, both should look like 192.168.1.x. If one is 192.168.0.x, there’s your issue.
  5. Remove old remotes. Fire TV sometimes keeps stale phone pairings. Go to Controllers and Bluetooth Devices, Amazon Fire TV Remotes, and clear old entries if you see them.
  6. If your TV has HDMI-CEC, use your TV remote to move around Fire TV menus while testing. Faster than fighting the app.
I half disagree with @mikeappsreviewer on switching apps first. A different app might connect, sure, but if local discovery is blocked, most apps fail the same way. Fix the network piece first. If the Amazon app still refuses after that, then try a third-party remote app as a workaround. I had this after an iOS update and Local Network permission was the dumb little fix.
I’d check one thing neither @mikeappsreviewer nor @suenodelbosque really dug into: app permissions/state corruption on the Fire TV side, not just the iPhone side.
Go to Fire TV Settings > Applications > Manage Installed Applications > Fire TV Remote App or system remote-related services if listed, then clear cache. If there’s an option to force stop any Amazon remote/control service, do that too. I’ve had Fire OS get weird where the TV is “visible” on the network but won’t accept a new phone session.
Also, try this dumb-but-real fix: change your iPhone name in Settings > General > About > Name, then retry pairing. Some discovery bugs seem tied to stale device records.
Another angle is router DHCP. If your Fire TV got a new IP but the app cached the old one, it just sits there acting broken. Rebooting helps sometimes, but manually reserving an IP for the Fire TV in the router can stop the random disconnect nonsense.
I kinda disagree with jumping straight to another remote app. If the built-in pairing service on Fire TV is hung, third-party apps can fail too. That said, if you just need control right now, using an alternative remote app temporarily is a fair workaround while you sort the actual issue.
Last thing, if your physical Fire TV remote still works, go to Network and actually watch whether Wi-Fi signal is fluctuating. I had one that looked connected but kept dropping for a split second, which was enough to kill app pairing. Super annyoing.
