I’ve been testing Ourdream AI for generating images and I’m getting mixed results, with some outputs looking great and others totally missing the prompt. Before I invest more time or upgrade, I’d really appreciate detailed feedback from people who’ve used it longer. Is it worth it compared to other AI image tools, and are there any tips or settings that make a big difference in quality and consistency?
I’ve been playing with Ourdream on and off for a few weeks. Mixed bag is a good way to put it. Here is what helped me get more consistent results before paying for anything.
Be very literal in prompts
Ourdream tends to ignore vague stuff.
Bad: “cyberpunk girl in a cool city, detailed, atmospheric”
Better: “portrait of a 25 year old woman, neon city background, blue and pink lights, head and shoulders, facing camera, photography, 50mm lens, sharp focus, no text, no watermark”The more concrete nouns and clear attributes you give, the closer it sticks. Avoid stacking too many abstract adjectives.
Control style with short tags
Stuff like “anime”, “3d render”, “photography”, “concept art”, “oil painting” works better than long art descriptions.
If you mix styles, it tends to get confused. Pick one main style per prompt. -
Use negative prompts every time
Ourdream seems prone to extra fingers, weird eyes, and stray text.
Try a default negative prompt like:
“text, watermark, logo, extra limbs, extra fingers, deformed hands, blurry, out of frame, disfigured, distorted face, low quality, duplicate face”
Save that and reuse it. It cleaned up a lot of my messier results. -
Give it fewer tasks per image
If you ask for a full scene with complex composition, multiple characters, and specific objects, it starts dropping parts of the prompt.
Example that often fails: “two knights fighting a dragon on a cliff at sunset, castle in background, village below, smoke, dramatic lighting, cinematic, wide shot”
Split your goals. Do simpler scenes, then use an editor or inpainting if the platform supports it. -
Be strict with aspect ratio and subject
If you want a character focus, choose portrait ratio. For environment, use landscape.
When I stopped asking for “epic wide shot of full body + background + tiny objects”, the hit rate improved a lot. -
Compare against known models
If you used Midjourney or SD 1.5/XL before, Ourdream feels closer to generic diffusion models with some tuning. It does portraits and stylized art better than complex storytelling scenes.
If your main goal is cool profile pics, posters, or single subject art, it does ok. If you want precise product mockups or strict adherence to multi-step instructions, it struggles. -
Prompt testing strategy before paying
Before you upgrade, do this:
• Pick 3 prompt types you care about most, for example: portraits, full body, environments.
• For each type, write 3 prompts: simple, medium, complex.
• Run 3 images per prompt.
• Rate 1 to 5 for each: likeness to prompt, anatomy, style match, overall quality.If your average score stays under 3 for what you actually need, I would not upgrade. If simple and medium prompts hit 4 and above and only the crazy complex ones fail, then the paid plan might be worth it for you.
Things it did well for me
• Anime portraits
• Stylized fantasy characters
• Simple “product on plain background” shots
• Concept art style environments if I let it be loose and not super specific -
Things it often missed
• Accurate text on objects
• Multiple characters interacting in a clear way
• Very specific fashion details or logos
• Perfect hands on full body shots
If you share one of your prompts that failed and the result type, people here can suggest tweaks. The tool is not useless, but you need to treat it more like a stubborn model that listens best to short, concrete instructions.
I’m in the same “mixed results” boat with Ourdream, but I’ll come at it from a slightly different angle than @espritlibre.
Couple of points from my own testing:
Don’t always be too literal
I actually found that over-specifying sometimes makes Ourdream seize up and ignore half the prompt. If I cram in 25 attributes, I start getting generic “close enough” results.
What helped:- One clear subject
- 3–5 key visual traits (age, clothing, mood, setting)
- 1 style word
That’s it. Then I iterate from there instead of writing a novel in the prompt.
Reroll instead of rewriting everything
The model’s super stochastic. When it “misses” your prompt, it can still be on the edge of the right concept. I’ve had:- First image: total mess
- Second/third with same prompt & params: suddenly nails it
So before spending energy on huge prompt surgery, try generating 2–4 variants with minor tweaks. That gave me more mileage than I expected.
Pay attention to CFG / “prompt strength” (if exposed)
If Ourdream lets you change guidance strength like SD:- Too low: it vibes more than follows the text
- Too high: it locks into a weird, overbaked look & ignores nuance
I hovered around mid-range and only nudged it when it kept hallucinating stuff I didn’t ask for.
Use reference images if your use case needs accuracy
For faces, poses, or products, text alone is not great on Ourdream. Whenever I used:- Pose refs
- Face refs
- Simple product photos
I got way more “on-brief” outputs than with words alone. For me that was the difference between “cool but random” and “actually usable.”
Calibrate your expectations by type of task
From my tests:- “Vibe / mood” images: solid
- Stylized characters: decent
- Product, UX, logos, or anything that must be precise: meh
The mistake is expecting it to act like a deterministic design tool. If your main goal is commercial-precision stuff, I’d be very cautious about upgrading.
Test for consistency not just one-off bangers
The question isn’t “can Ourdream produce one amazing shot?” but “how many misses per hit?”
I ran a simple check:- Picked one exact prompt
- Generated 10 images
- Counted how many were “usable” without editing
If I’m getting 2/10 usable for my main use case, I don’t pay. If I get 6–7/10, then the paid tier might be worth the speed & higher limits.
Be honest about how you’ll use it
- Casual art, wallpapers, character inspo: the randomness is actually kind of fun
- Client work, merch, book covers: the inconsistency starts to hurt, even if you get some gorgeous outputs
If you post one failed prompt + the result type you wanted (not even the image, just describe it), people here can probably tell you fast whether Ourdream is the problem or the prompt is overkill for what this kind of model handles well.
Try a side-by-side cost test instead of more prompt tuning. Use the same five prompts in Ourdream and one free alternative. Generate four images per prompt. Score prompt accuracy, visual quality, editing time, and cost.
Example: Ourdream gives 6 usable resuts from 20, while the alternative gives 11. Divide total cost by usable images. Pick the cheaper tool with less editing.
Set a 30-minute limit. If Ourdream loses, dont upgrade. This gives you a clear answer without spending days tweaking settings.
A single-subject portrait at portrait ratio will land maybe most of the time. Ask the same tool for a labeled bottle on a shelf with readable brand text, and it falls apart no matter how clean your prompt is. That gap is the whole story with Ourdream, and no amount of prompt polishing closes it.
That’s where I’d gently push back on @espritlibre. All the literal-prompt advice is solid for the first case and basically wasted on the second. Text on objects, exact logos, precise spatial relationships between multiple things, those are model limitations, not prompt problems. You can rewrite that knights-and-dragon prompt fifty ways and still get a dropped village. So before you tune anything, sort your use case into ‘the model can physically do this’ versus ‘it can’t.’ Save the tweaking for the borderline stuff.
@cazadordeestrellas is right that overloading the prompt backfires, and the reroll point is the one I’d underline hardest. These models are random enough that ‘it missed’ and ‘it can’t’ look identical after one generation. If you judge on a single output you’ll throw away prompts that actually work. Run the same thing a few times before you conclude anything.
The reference image tip is the real unlock though, and I’d put it above almost everything else here. If accuracy matters to you, text prompts alone on this kind of model are always going to feel like negotiating. Feed it a pose or face or product shot and you skip half the guesswork. If your work needs that and Ourdream’s reference support is weak or limited on the free tier, that alone tells you whether upgrading is worth it, more than any prompt score.
One thing nobody flagged: watch what the paid plan actually buys you. On most of these tools it’s speed, resolution, and higher limits, not better prompt adherence. If the free tier misses your prompts, paying usually just lets you miss them faster and bigger. Confirm the paid tier changes the model or unlocks features you need before assuming the quality jumps.
