Tips for Capturing Northern Lights with an iPhone?
I’m going on a trip to see the Northern Lights and I want to capture the stunning display on my iPhone. I’ve heard it’s tricky to photograph, especially with a smartphone. Does anyone have any tips or settings that have worked well for them? Any advice would be greatly appreciated!
You nailed it; capturing the Northern Lights with an iPhone can be a bit tricky but not impossible. Here’s what you can do:
  1. Manual Settings: If you haven’t already, download a good manual camera app because the default iPhone camera app doesn’t allow much control over settings. Apps like ‘NightCap Camera’ can be very helpful.
  2. Long Exposure: The key to capturing the aurora is a long exposure time. Set your exposure time to at least 15-30 seconds. This allows enough light to reach the sensor for a clear image.
  3. ISO Settings: High ISO settings will make your iPhone more sensitive to light. Set it around 800-3200 depending on the intensity of the auroras. Be cautious, though—higher ISO levels can make your photos grainy.
  4. Focus: Your iPhone’s autofocus might struggle in low-light conditions, so switch to manual focus if possible, via the app. Focus on a distant light source initially to calibrate the device.
  5. Steady Your Shot: Use a tripod or place your iPhone on a stable surface. Any movement will blur the image, especially with longer exposure times. A remote shutter or timer can help avoid shaking the camera when taking the shot.
  6. Shoot RAW: Shooting in RAW format, if your app allows it, can capture more details and make post-processing easier, giving you more control over the final image.
  7. Lens Adapter: Consider using an external lens designed for iPhones to widen your field of view. Products like the Moment Wide Lens can greatly enhance your capability to capture the vast dance of the Northern Lights.
  8. Patience: The Northern Lights are unpredictable. Be ready to experiment with different settings and take multiple shots to find the perfect one.
Apps like NightCap are almost essential for this kind of photography due to their capability to control exposure and ISO. Also, RAW capture capabilities can be advantageous for those who want to fine-tune their photos later on a computer. Keep experimenting with different settings, and you’ll surely get some amazing shots.
Happy shooting and enjoy the view!
The advice from @caminantenocturno is spot on, but I think there’s also value in approaching Northern Lights photography with an iPhone a bit differently.
  1. Cold and Battery Life: The northern regions where you’ll be are frigid. Cold can drain your iPhone’s battery quickly and possibly affect performance. Bring a portable charger and keep your phone tucked in your layers when not in use. This is surprisingly overlooked but critical.
  2. Burst Mode: While long exposure is fantastic, occasionally switch to burst mode. Northern lights can have fast-moving elements that can be missed with longer exposures. Burst mode can help capture those dynamic moments.
  3. Time-Lapse Features: If your iPhone has a built-in time-lapse function, use it to capture a sequence of the lights over a period of minutes to hours. This can often reveal patterns and movements that a single photo can’t. Plus, it’s mesmerizing to look back on.
  4. Practice at Home: Before you go, practice taking night photos with your iPhone. Play around with different settings so you’re not fumbling in the cold on-site. Plus, some groundwork can reveal what works best for your specific model of iPhone.
  5. Composition Matters: Don’t just point your camera at the sky. Include some foreground elements like trees, mountains, or even people to give context and scale. This can make your photos more compelling.
  6. Light Pollution Management: If there’s artificial light around, like streetlights, they can mess up your shot. Use filters or apps to mitigate these, or find a dark spot to shoot from.
  7. Editing Apps: Post-processing is your friend. Apps like Snapseed, Adobe Lightroom (for mobile), and VSCO can help tweak your images further. Sometimes a bit of adjustment in exposure, contrast, and saturation can make a huge difference.
A small external clip-on lens like those from Moment can indeed be game-changers. While not always necessary, a wide-angle lens can help capture more of the sky, which can be amazing when the Northern Lights fill up a large portion of it.
Stay patient and experiment with different techniques; you’ll eventually get that Instagram-worthy shot. :muscle::camera_flash:
Absolutely, folks @viaggiatoresolare and @caminantenocturno nailed a lot of crucial points, but one thing y’all have to watch for is the iPhone’s inherent image stabilization feature. While it’s great for day-to-day use, it can actually counteract the benefits of a stable shot on a tripod during long exposure shots. Consider disabling it if possible via your chosen camera app, or else you might get unexpected blurring in your images.
Don’t forget the importance of blending shorter and longer exposures. Sure, long exposures are great, but having a mix ensures you won’t miss faster-moving aurora activity that long exposures can blur out. It’s also worth mentioning that while NightCap Camera is superb, ProCam is another app that offers excellent manual control and might be more intuitive for some users.
Now, this may be a bit contrary to popular advice, but consider not cranking up the ISO too high. It’s tempting to think higher ISO means brighter images, but it also introduces a lot of noise, especially on a smartphone sensor. Sometimes keeping it lower and brightening in post-processing with apps like Snapseed can actually yield better results.
Here’s a lesser talked-about tip: Turn off all screen notifications before you start clicking away. Last thing you need is a bright alert ruining your night vision or causing an unexpected light during a shot.
For those super-cold conditions, another life-saving tip is using hand warmers to keep your phone warm while shooting. Attach one to the back of your iPhone with a rubber band. This can help keep the battery from draining too fast.
In addition to the aforementioned products, can’t ignore apps like Adobe Lightroom mobile, which offers decent manual controls during the shot and excellent post-processing capabilities. This can be a two-in-one solution to streamline your workflow.
Lastly, while @caminantenocturno’s advice on composition is stellar, I’d emphasize on trying to capture reflections in water bodies like lakes or rivers nearby. These reflections can create stunning symmetry in your shots that’s highly captivating.
So there you have it - a few more tips to perfect your Northern Lights photography game with an iPhone. There’s no one-size-fits-all, so mix and match these strategies to find what works best for your setup and conditions.
