Why Does Upload Speed Feel Faster Than Download Speed?
My upload finished much faster than the download test suggested it should, and I do not understand why. I was sending a folder of phone photos to cloud storage while my laptop was plugged into the router. The speed test showed download speed far above upload speed, but the folder transfer moved steadily while a software update on the same laptop crawled.
I paused the photo upload, restarted the router, and ran the test again from the same desk. The result still favored download speed, yet actual downloading felt slower. Am I comparing different measurements or missing overhead somewhere? Do other people see upload speed and download speed behave this differently in normal use?
A speed test measures a clean transfer to a nearby test server, while your software update depends on the vendor’s server, routing, and lots of smaller requests. Cloud photo uploads may use several parallel connections and show progress based on compressed or deduplicated files, so they can feel faster than expected. Run the internet speed test, then compare actual file sizes and elapsed time in megabytes per second. Remember that speed tests report megabits, while apps often report megabytes, an eight-to-one difference.
Don’t trust the folder’s progress bar as proof that every full-size photo has already reached the cloud. Some sync apps finish the visible “copy” stage first, then continue transferring in the background. They may also skip photos already stored, upload only changed files, or report the folder’s logical size rather than the number of bytes actually sent.
@shadowwizardedge is right about checking bits versus bytes, but parallel connections cannot magically exceed your internet connection’s total upload capacity. Plugging the laptop into the router only removes Wi-Fi as a possible bottleneck. It does not change the upload limit from your provider.
Check the cloud service through its website, confirm the photo count and original file sizes, and look for a status such as “sync complete.” If you time another upload, use a new large file that has never been uploaded before. That gives you a much cleaner comparison than a folder full of photos that the app may deduplicate or process differently.
A faster-than-expected upload can hide a reduced-quality backup setting. Some cloud apps resize or compress phone photos before sending them, so the actual upload may be much smaller than the folder on your laptop. Check whether the service is set to “original quality” or a storage-saving mode before comparing it with Speedtest by Ookla.
The download result is not the number you should use to predict an upload. They are separate directions with separate limits, and many internet plans provision them very differently. A test showing 300 Mbps down and 20 Mbps up means your photo transfer should be judged against the 20 Mbps figure, not 300.
Use the upload result and calculate from the bytes actually sent. As a rough check, divide megabits per second by eight to get megabytes per second. At 20 Mbps, the ideal maximum is about 2.5 MB/s, before protocol overhead and normal fluctuations. If the cloud app supposedly moved 10 GB in a couple of minutes on that connection, it plainly did not transmit 10 GB of new data during that period.
I would not put much weight on ordinary compression here. @pixel2101 is right that a storage-saving setting can resize photos, but JPEG and HEIC files are already compressed, so merely zipping or compressing them in transit usually will not explain a huge difference. Deduplication, existing phone backups, thumbnails, or an inaccurate progress indicator are more believable explanations.
For a clean test, watch the laptop’s network usage while uploading one large, newly created file. Start timing when outgoing traffic begins and stop only when the cloud site can download the same file. That bypasses folder-size quirks and makes it much harder for the sync app’s status display to fool you.
The hidden catch is that many cloud clients start sending data before the visible upload timer or progress bar really gets going. While the app says it is “preparing,” scanning, or counting photos, bytes may already be leaving the laptop. Timing only the obvious progress stage can make the transfer look impossibly fast.
Watch the actual outgoing traffic instead. Pause automatic photo sync, create a new large file, and open Task Manager or your router’s traffic graph before selecting it. Start timing at the first sustained outbound activity, then stop when that traffic falls back to idle and the file is available through the cloud website.
There is another timing wrinkle: “uploaded” may mean the nearest cloud intake server accepted the file, not that every server-side copy, thumbnail, and backup operation has finished. That is normal, but it makes app progress a poor tool for measuring your connection. Compare the sustained network rate with the speed test’s upload result, rather than comparing two progress bars.
Pull up your operating system’s built in data usage counter before you fiddle with anything else. Windows keeps a running total in the network settings, and most phones show cellular plus Wi-Fi usage too. That cumulative byte count is harder for a sync app to spin than a progress bar, because it’s the network stack counting, not the app reporting. If you note the number, run the upload, then check again, the difference is roughly what actually left the machine.
The reason I’d start there instead of Task Manager timing like @quinn suggested: watching live traffic works, but you have to babysit it and you’ll second guess when to start and stop. A before and after counter reading is lazier and honestly cleaner for a one off check.
On the folder of phone photos specifically, I think the real culprit is sitting in plain sight. Those same photos were very likely already backed up by the phone app itself. So when your laptop tried to send them, the service saw matching hashes and skipped the bytes entirely. That’s not compression, that’s the server saying ‘already got it, thanks.’ @megathread nailed this and I’d weight it heavier than the quality setting angle. Resizing HEIC or JPEG barely moves the needle, but skipping a few gigabytes of duplicates makes an upload finish in seconds.
One more thing people forget with thousands of small files: per file overhead usually makes that kind of transfer slower per megabyte, not faster. So if a folder of photos felt quick, it almost certainly wasn’t pushing all the original bytes. A single fresh large file is the only fair yardstick against your Speedtest by Ookla upload number. Just make sure it’s genuinely new content, otherwise dedup ruins the test again.
The missing detail is whether the speed test ran while the cloud client, your phone, or another device was still syncing. A speed test measures whatever capacity is available at that moment. It does not automatically pause background traffic. If the photo app was already using most of the upstream connection, the test would report only the remaining bandwidth.
A saturated upload can even drag down the download result. Downloads still need to send acknowledgments upstream, and those tiny packets can get stuck behind a long queue of photo data. That creates the odd situation where the connection feels better during the upload than the download test looks on paper. Ethernet does not prevent this because the congestion is at the internet side of the router, not between the laptop and router.
The clean retest is to pause cloud sync on every device, disable any VPN, wait until the router shows almost no WAN traffic, and then run the test. Afterward, upload a genuinely new file and watch the router’s outbound rate. I agree with @anna_ai that byte counters are useful, but they only prove how much the laptop sent. They will not reveal another device competing for bandwidth or a router queue distorting the speed test.
A folder that shows 8 GB in Explorer and an upload job that accepts that folder are not necessarily processing the same 8 GB. Photo folders can contain sidecar files, thumbnails, edited copies, short video clips, and formats the cloud client ignores or handles as part of another photo. The app may quietly skip those without making the progress display very clear.
For a cleaner comparison, put the folder into a single uncompressed archive and upload that archive. Since JPEG and HEIC files are already compressed, the archive should remain close to the original size, but the cloud service now sees one ordinary file instead of thousands of photo assets it can filter, merge, or deduplicate individually.
If that archive transfers at roughly your tested upload rate, the connection was never unusually fast. The original photo upload simply sent fewer bytes than the folder size implied.
