Why is my AT&T WiFi suddenly so slow and dropping devices?
My AT&T WiFi has been randomly slowing down and disconnecting multiple devices over the last few days, even though I haven’t changed any settings or moved the router. Streaming buffers, online games lag, and video calls keep cutting out. I’m not very technical and I’m not sure if this is a modem, router, or ISP issue. What steps should I take to troubleshoot AT&T WiFi problems and figure out if I need a new router, a technician visit, or a different plan?
AT&T doing AT&T things again.
When WiFi slows down and starts dropping stuff out of nowhere, it is usually one of these:
  1. AT&T side issues
    • Log in to your AT&T account.
    • Run their speed test from their site, not a random one.
    • Compare:
      • What you pay for, like 300 Mbps.
      • What the AT&T test shows to your gateway.
    • If AT&T test shows low speed, the problem sits before your WiFi. Call support, ask them to check line quality, noise margin, and errors on the line. Ask for a line test and a profile reset.
  2. Your gateway overheating or glitching
    • Touch the gateway. If it feels hot, give it more space.
    • Power cycle it: unplug 30 to 60 seconds, plug back in, wait 5 minutes.
    • If you have had the same gateway for years, it might be failing.
    • Look at the lights during a drop.
      • Broadband light blinking or red = line issue.
      • WiFi light blinking hard nonstop = local congestion.
  3. Interference and channel problems
    • Neighbors, new devices, baby monitors, smart plugs, etc, can trash 2.4 GHz.
    • Log into the AT&T gateway, change:
      • 2.4 GHz to channel 1, 6, or 11.
      • 5 GHz to a different channel band like 40 or 80 MHz width if available.
    • Split SSIDs:
      • Name 2.4 GHz and 5 GHz differently, ex: MyWifi2G and MyWifi5G.
      • Put older smart devices on 2.4G.
      • Put phones, laptops, consoles on 5G.
  4. Too many devices or one device hogging bandwidth
    • One device syncing cloud backups or torrents will wreck streaming.
    • During a lag spike, open your router device list.
    • Turn off WiFi on devices one by one, or unplug suspects.
    • Check if someone is using a VPN or downloading large game updates.
  5. Bad WiFi placement
    • Keep the gateway in the open, chest height, not behind a TV, not in a closet.
    • Avoid placing it next to a microwave or thick walls.
    • If your house is bigger or multi floor, the single AT&T gateway signal will drop off hard. That is normal, not special to AT&T.
  6. Use a WiFi survey tool
    • This part helps a lot and almost nobody does it.
    • Install something like NetSpot on a laptop.
    • Walk around your place and map signal strength and noise.
    • You see exactly where things drop and which channels are crowded.
    • Try this link for that type of tool: analyzing and improving your home WiFi signal.
    • After you see the map, adjust channel, move the gateway, or add an access point where signal dips below about -70 dBm.
  7. Bridge mode plus your own router
    • If you want more stable WiFi, you use the AT&T box for internet only.
    • Put it in IP passthrough, then connect your own decent WiFi router.
    • Your router handles WiFi. AT&T handles the fiber or DSL.
    • This fixes a lot of random drops on busy homes.
  8. When to push AT&T
    • If line test from their side looks bad.
    • If your gateway reboots on its own.
    • If you see frequent packet loss on ping tests, like ping 8.8.8.8 -t on Windows, and you see spikes or timeouts often.
    • Ask for a replacement gateway or a tech visit. Be firm, not nice. Use words like “intermittent service” and “packet loss” and “line noise”.
Quick checklist for you
  • Reboot gateway.
  • Separate 2.4G and 5G SSIDs.
  • Change channels.
  • Run an AT&T internal speed test.
  • Map WiFi with something like NetSpot.
  • If issues keep happening on wired devices too, push AT&T for line and gateway replacement.
If wired works fine but WiFi sucks, it is almost always interference, placement, or the AT&T gateway WiFi being weak, not your service tier.
AT&T randomly going potato like that in a few days usually means something actually changed, just not anything you did on purpose.
I mostly agree with @viajeroceleste, but I wouldn’t jump straight to “buy your own router” or “bridge mode” unless you’ve nailed down the real bottleneck first. Band-aids on a mystery problem just give you two boxes to debug later.
Here are a few angles they didn’t really dig into:
1. Check if it’s only WiFi devices or also wired
This is the fastest way to separate “AT&T problem” from “WiFi problem.”
  • Plug a laptop or desktop directly into the AT&T gateway with Ethernet.
  • When your WiFi is acting like trash, run:
    • ping 8.8.8.8 -t (Windows) or ping 8.8.8.8 (Mac/Linux)
    • A speed test from AT&T’s own site and maybe one external (like Ookla)
If the wired connection is still smooth while WiFi is dying, your internet line is probably fine. No need to scream at AT&T yet; you’re dealing with local RF hell.
If wired also lags or drops, then it’s upstream or a bad gateway and AT&T’s on the hook.
2. WiFi “optimization” features that actually break stuff
AT&T gateways love to turn “smart” features on by default that end up being dumb in real life:
  • Band steering / “Smart Wi-Fi”
    This tries to move devices between 2.4 GHz and 5 GHz automatically. A lot of IoT and older devices freak out and keep disconnecting.
    • If possible in your AT&T gateway settings, disable anything labeled Smart Wi-Fi, band steering, or similar.
    • Keep 2.4 GHz and 5 GHz as separate SSIDs like viajeroceleste suggested, then leave them that way, don’t let the gateway merge them again.
  • MAC randomization + crappy firmware
    Newer phones randomize their MAC address per network. Some AT&T firmware versions bug out and treat that like “new device every time” and start mismanaging leases.
    • On your main phone or laptop, set WiFi to use a private MAC off (use phone’s actual MAC) for your home network only.
    • See if that reduces the random disconnects.
3. DHCP lease issues or device limit nonsense
A lot of these gateways start glitching once you hit a certain number of devices, especially with smart plugs, bulbs, cameras, etc.
  • Log into the gateway and look at the device list.
  • If you see a ton of “inactive” devices or stuff you don’t recognize, clear them out if the interface allows it.
  • If your DHCP pool is tiny (like 192.168.1.2 to 192.168.1.50) but you have 40+ devices, enlarge the pool so leases don’t collide or expire constantly.
Random disconnects every few hours can literally just be the router choking on too many leases.
4. Hidden interference that shows up “suddenly”
You said you didn’t move the router or change settings, but new interference can appear overnight:
  • Neighbor installed a new mesh system or a new ISP router blasting on the same channels.
  • Someone nearby added a wireless security camera system or “whole home” baby monitor.
  • New microwave, cordless phone, or even holiday lights with crappy power supplies.
Instead of guessing, use a WiFi analyzer:
  • Install NetSpot on a laptop or desktop and walk around your place.
  • Look at which channels are busiest, where signal drops and where noise is high.
    It’s honestly one of the easiest ways for making your home WiFi actually usable without just yelling at your ISP.
  • If you see your 2.4 GHz network sitting right on top of 5 other loud networks, move to a cleaner of 1 / 6 / 11 that has lowest overlap.
This is where I actually disagree a bit with the “just try 1, 6 or 11” approach: don’t just pick randomly. Use a tool like NetSpot, look at the graph, and choose the least congested one instead of rolling dice.
5. Firmware and auto updates timing
AT&T pushes firmware to gateways silently. Sometimes the update is buggy and causes:
  • Memory leaks
  • WiFi radios locking up after some uptime
  • Random reboots or soft hangs (WiFi dies, lights look “normal”)
If you notice it gets worse after the gateway’s been on for a day or two:
  • Power cycle it and see how long it behaves before acting up again.
  • If it always dies after similar uptime, that screams firmware or hardware fault.
  • When you call support, explicitly mention “intermittent after a day of uptime” and ask if your model has a known firmware issue or if they can push an update or swap the unit.
6. Latency vs speed: which one’s actually killing you
You mentioned streaming buffering and game lag. That can absolutely happen even when speed tests look fine:
  • While lagging, run a continuous ping:
    • To your gateway (usually 192.168.1.254)
    • To an external IP like 8.8.8.8
  • If pings to your gateway are spiking or dropping, that’s local WiFi or the gateway choking.
  • If gateway pings are fine but 8.8.8.8 spikes, that’s upstream congestion or AT&T issues.
AT&T support will pay more attention if you say:
“I’m seeing 5 to 20 percent packet loss and ping spikes every few minutes, even when speed tests look normal.”
That sounds way more convincing than “Netflix keeps buffering.”
7. When a separate router actually makes sense
I wouldn’t start here, but if you confirm:
  • Wired speeds are fine and stable
  • Packet loss is zero or near zero wired
  • All the weirdness is only over WiFi
  • You’ve already tried different channels, separated SSIDs, and rebooted
Then yeah, at that point the WiFi radios in the AT&T box are probably subpar or dying.
Use:
  • AT&T gateway in IP passthrough mode
  • A decent third party router handling WiFi and DHCP
  • AT&T box just doing modem duty
It doesn’t fix a bad AT&T line, but it does usually stop the random disconnect circus caused by cheap integrated WiFi.
Cleaner version of your situation for clarity / searchability
Why is my AT&T WiFi suddenly so slow and constantly dropping devices?
Over the last few days, my AT&T WiFi has started randomly slowing down, kicking multiple devices off the network, and making everyday tasks painful. Streaming services keep buffering, online games lag like crazy, and video calls freeze or disconnect altogether. I haven’t changed any WiFi settings, moved the AT&T gateway, or added new equipment, yet the performance has gone from stable to unreliable almost overnight.
If you want a quick order of attack:
  1. Test a wired device during the problem.
  2. Watch pings to gateway vs 8.8.8.8.
  3. Disable band steering / Smart Wi-Fi, split SSIDs.
  4. Check DHCP pool and excess devices.
  5. Use NetSpot to see channel congestion and move accordingly.
  6. If wired is bad too, start harassing AT&T for line tests and a gateway swap.
You’re not crazy; this kind of “suddenly trash” behavior is weirdly common with ISP-supplied gear.
Short version: what they said, but with a different angle on “what actually changed” and whether this is worth fighting AT&T over.
You already got the main playbook from @waldgeist and @viajeroceleste, so I’ll avoid rehashing the same checklists and focus on things people usually skip.
1. Think in “scopes”: where exactly is it broken?
Instead of trying 12 tweaks at once, narrow the blast radius:
  • Scope A: Only some WiFi devices drop (e.g., older IoT, smart TV).
  • Scope B: All WiFi devices go slow or drop together, but wired is OK.
  • Scope C: Both wired and WiFi are trash at the same time.
If it is:
Scope A
Likely a compatibility / band steering / power saving issue on specific clients, not the whole network. In that case, focus on:
  • On those specific devices, turn off aggressive WiFi power saving or “auto” roaming.
  • For older 2.4 GHz gear, lock them to 2.4 only and avoid fancy mixed-mode features on the gateway like “optimize for performance” that sometimes breaks legacy stuff.
Scope B
That is where @viajeroceleste’s interference and channel suggestions matter most. Also:
  • Watch if performance tanks right after “one heavy device” wakes up. Gaming console, cloud backup app, Plex server. If your AT&T box has weak QoS, one session can bulldoze the rest.
Scope C
That is AT&T line, gateway hardware, or upstream congestion. No channel change will save you there. This is where @waldgeist’s push-AT&T advice is on point.
2. One thing I disagree with slightly: “don’t buy your own router yet”
I get the logic of not slapping band-aids on.
However, AT&T gateways are famous for marginal WiFi once you have:
  • Many devices (25+)
  • Any mix of smart home gear plus streaming plus gaming
If you confirm wired is rock solid for hours while WiFi falls apart repeatedly, that is enough evidence for me to justify putting the AT&T box in passthrough and letting a real router run the show. You are not masking a mystery at that point, you are isolating it: line is good, radio is not.
3. Hidden “client side” changes that look like ISP problems
You said you changed nothing. Usually true from your perspective, but a few silent changes can blow things up:
  • OS updates
    Recent iOS / Android / Windows patches sometimes change how aggressively devices roam, sleep, or randomize MACs. If stuff started right after a system update, check that device’s WiFi settings first.
  • New background workloads
    Things like:
    • Phone photo library doing a huge “once in a while” cloud sync
    • Steam or console auto-downloading a giant game patch
    • A PC doing OneDrive / iCloud / Google Drive re-sync after update
Even with a decent plan, a single upload-heavy task can make latency horrible. Check task managers and update queues on PCs and consoles at the exact time lag starts.
4. Where NetSpot fits into this, with pros and cons
Since both @waldgeist and @viajeroceleste mentioned surveying your WiFi, I will be blunt: eyeballing signal bars is useless. A tool like NetSpot actually shows you how bad your environment is.
Pros of using NetSpot in your case:
  • Visual heatmaps of signal strength so you see where the AT&T gateway really fails.
  • Channel congestion view that tells you which channels are full of neighbors instead of guessing.
  • Noise and interference readings that can reveal if your slowdown is more “RF soup” than “AT&T evil.”
  • Great for deciding: move the gateway, add an access point, or justify that new router.
Cons to be aware of:
  • Needs a laptop and some time walking around, so it is not a 30‑second fix.
  • The data can look overwhelming if you are not comfortable with RSSI, SNR, channel overlap.
  • It identifies the symptom environment (crowded channels, weak spots), but it cannot fix an upstream AT&T line or a dying gateway radio by itself.
  • If you only have a tiny apartment and 5 devices, the benefit is lower; in that case, it may feel like overkill.
Used right, NetSpot answers: “Is this a WiFi design/interference problem, or am I justified in harassing AT&T or replacing hardware?”
5. Watch for patterns in time, not just symptoms
This is something neither of them pushed hard, but it is huge:
  • Does it fall apart at roughly the same time every evening?
    Could be neighborhood congestion or AT&T oversubscribing a node.
  • Does it only die after the gateway has been up a day or two?
    Strong hint of firmware memory leak or overheating.
  • Does it die when you start specific tasks (Zoom, PS5 game, Netflix on a certain TV)?
    That narrows it to specific devices or traffic types.
Write down 3 or 4 episodes with:
  • Time of day
  • What devices were active
  • What each symptom was (speed test result, ping result, which devices dropped)
If you call AT&T, that log is gold. If you troubleshoot locally, it keeps you from chasing random one-off coincidences.
6. Two “weird but real” causes AT&T users hit
  1. Bad power to the gateway
    Power strips with surge protection or cheap UPS units can go flaky. If your gateway is on some overloaded strip, try a direct wall outlet. Brown-outs or noise on the DC side can make WiFi crash without the gateway fully rebooting.
  2. Half-broken coax / fiber path inside the house
    For some setups, wall jacks, ONT patch cords, or the tiny fiber pigtail can get slightly damaged. Wiggle does not disconnect fully, but adds just enough errors that the gateway spends its time correcting packets instead of passing traffic smoothly. If you see occasional brief red or blinking broadband lights, mention that explicitly to AT&T.
7. When you finally decide “this is not worth it”
If after:
  • Verifying wired vs WiFi
  • Checking for heavy background traffic
  • Mapping WiFi with something like NetSpot
  • Tweaking channels and basic settings
you still get constant drops and slowdowns, you basically have three realistic moves:
  1. Gateway swap from AT&T
    Use the exact phrases @viajeroceleste mentioned like “intermittent service” and “packet loss.” Also mention any red / blinking lights you have observed.
  2. Own router in passthrough
    Especially if wired is perfect and the house is mid‑sized or bigger. This pulls WiFi duty away from the weakest link.
  3. Adjust expectations for 2.4 GHz junk
    Some cheap smart plugs, bulbs, or ancient tablets are never going to be rock‑solid in a crowded 2.4 GHz neighborhood. Accept that those might always be second‑class citizens and prioritize your main devices on 5 GHz or better hardware.
Bottom line:
Use AT&T’s own tests and some targeted tools to pin down whether this is:
  • AT&T line / gateway failure
  • Local WiFi environment rot
  • A single noisy or greedy device
Once you know which bucket you are in, the fix is way less guesswork and a lot less “reboot and pray.”
Try a clean-network reset. Factory-reset the AT&T gateway, then create a new WiFi name and password. Do not reuse the old name, since devices will reconnect at once.
Conenct one phone first and test streaming for 20 minutes. Add devices back in small groups, five at a time. Wait 10 minutes between groups.
If problems start after one group joins, seperate those devices and reconnect them individually. This quickly finds a faulty device, stale gateway config, or unwanted client without channel scans, heatmaps, or new hardware.
Skip the factory reset that @cyberhive2855lab suggested, at least as your first move. Wiping the gateway and rebuilding your network in five-device batches is a lot of effort for something that started ‘a few days ago’ with no changes on your end. If a config really got corrupted, sure, but you’re more likely to spend an afternoon rejoining smart plugs only to hit the same wall.
Here’s the angle nobody’s touched yet. If your 5 GHz is sitting on a DFS channel, roughly channel 52 up through 144, the gateway is legally required to bail off that channel the instant it thinks it hears radar. Weather stations, airport radar, a neighbor’s new gear, all of it can trigger a detection. When that happens the radio goes quiet for a bit and every device on 5 GHz drops at once, then piles back on. It looks exactly like what you’re describing, and it can absolutely show up ‘suddenly’ if a new source turned on nearby or the gateway picked a DFS channel after its last reboot. Speed tests look fine between events, which is why it drives people nuts.
Easy check: log into the gateway, look at what 5 GHz channel it’s parked on. If it’s in that DFS range, lock it to a non-DFS channel instead. Channels 36, 40, 44, 48 on the low end or 149 through 165 on the high end never do the radar dance. This is a two-minute change and it’s free.
On the tool talk, NetSpot is genuinely handy for seeing which channels your neighbors are crowding, and I’d agree with @waldgeist that picking 1/6/11 by feel is a waste. But be clear about its limit here: a survey shows you a snapshot of congestion, it won’t catch a DFS radar boot because that’s an event, not a steady state. So use it to pick a clean channel, then confirm the drops actually stop over a day or two.
The part I’d keep from @suenodelbosque is logging timestamps. Boring, but it’s the fastest way to tell a DFS drop (short, everyone on 5 GHz, then instant recovery) from a gateway memory leak (gradual, gets worse the longer it’s been up) from plain evening congestion (same clock time every night). Three or four noted episodes will tell you which bucket you’re in faster than any reset routine.
If wired stays perfectly stable through all of this, that’s your signal the line is fine and you’re chasing an RF or firmware problem, not an AT&T outage. No point calling them yet in that case.
